1 - 10 of 10 Posts
I bought a 96 250 today, and it has a really rough idle. I think its a fuel issue but i wanted your input. It idles rough and is a really choppy idle. It does it from start up until shut down. The truck seems a little underpowered but i can feel the turbo kick in. I was going to check the ful pressure today but broke my fuel press. gauge. I think its a week lift pump. Just wanted to see if you guys had any ideas on things to check before i go buy a lift pump. I had the truck idling and pulled the icp and it did not change and the cel came on. Iturned the truck off and plugged icp back in and the check engine light was gone. Any ideas? By the way the truck is a standard and stock except for a straight pipe.
Discussion Starter · #2 ·
It looks like i have fuel in my intake valley. Anybody have any ideas where fuel can leak from in there?? Maybe the lift pump or the hoses going from lift pump to filter housing? Where have you guys found the cheapest lift pumps? I called ford and theres was $160.
Run your truck and look at you fuel filter reservoir.... i have a leak from mine, Make sure you get o rings that will hold up to diesel fuel too
Your leak can be any number of things old hoses,sensor on the side of the filter housing,or the pump itself, most likely though it is the pump itself there is a weep hole on the side of it when it starts to go it will leak there try cleaning up the fuel in the valley real good with some paper towel run the truck and maybe use a mirror to see where it is coming from.
good luck
Discussion Starter · #5 ·
ok thanks guys for the input. The choppy idle and underpower and sluggishness of the truck is driving me nuts. I`ll post after i get the chance to look.
Discussion Starter · #6 ·
Ok i`m leaking fuel, not sure where can`t quite pinpoint the leak. I checked my fuel pressure today and the needle bounces from about 45-60 (not liquid filled gauges). It has a rough idle, and until it ets some temp in it it is extremely underpowered, almost won`t move. Would a leak in the fuel system make it this underpowered and a rough idle. Once the truck warms it has more power, and if i ease into the accelorator it has more power. I was going to change the lift pump but it has decent pressure. Any thoughts? This is driving me nuts....
Discussion Starter · #8 ·
No, there is not a check engine light.
Discussion Starter · #9 ·
If it is getting air in the fuel system would it be underpowered?
Premium Member
between55-65 is where fuel psi should be, and the needle with bounce around alot since the stock pump is driven off a lob on the cam.... it pulses alot.
1 - 10 of 10 Posts
