1 - 10 of 10 Posts
do any of you guys run t6 5w40 synthetic oil? it seems like it would be good for these cold (10-25 deg.) temps. i worry that when it warms back up in the spring that the oil will be too thin. i dont want to harm my engine.
I run it in my 6.0 year round in tx
The oil is still 40 weight when it's hot
My 640 K truck fires up in negative temps without being plugged in. With 15-40 (non syn) it is a bear to start in single digit temps. Also is smoother.
Side note: glow plugs are over 400k old. Relay original. (640k)
I know that my compression is good.
Make the switch and don't think twice. My truck used to romp like crazy on cold mornings and now I've even forgot what a romp sounds like after making the switch. It'll make a whole world of difference with the cold starts.
Just a side note, don't fall into believing all that jibberish about how you gotta flush your motor out,drain your HPOP, etc. just drain the old oil, refill with t6 and be done with it.
i run t6 year around. went from amsoil to t6 and have never looked back
:whs: I switched in Nov when it just started getting colder, never going back. Huge difference in cold starts.
Glad too hear the positive results with the T6, I've got 4 gallons sitting in the garage for my next oil change which will be soon.:D
1 - 10 of 10 Posts
