1 - 17 of 17 Posts
· Transfer Student from TDS
Im looking at picking up a pratically new set of rims and tires for my early 99 F250 PSD, that were on a 2006 Ford PSD.
Rim Spec:
Rims: Monster XD Wheels 18"
Bolt pattern:8x170
Offset: -12mm
Back Space: 4.5"
Tires: Mounted 285 Nitto Dune Grapplers
Will these rims work on my truck? Currently Im running stock rims with Bridgestone Dueler Revos 285's.
· <-- it's like that
Offset is a tad bit close. Obviously the guy who originally bought those rims wanted them to stick out some on his truck, but I don't know if it's too close for yours to rub on the front leafs.
Just FYI: '99-04 Superduties wheels have different backspacing and offset than '05 and up. Also the lug nuts won't fit, different threading.
However, you are looking at aftermarket wheels. The backspacing specs that you posted is the same as the wheels I'm currently running on my truck, but I have a -25mm offset compared to your -12mm. Like I said, it might be close on your truck. Are the wheels local where you can drive your truck up, pop it on, and see if it fits?
I should be able to use my lug nuts on the rim right?
No the wheels are in new york :( So the offset with the lower number means it will be closer to the leaf springs. Is there a way I can check to see if I might hit my leaf springs?
· Registered
theyll work with no problem. i hade an early 99 witha leveling kit and i ran a 35x1250x17. the wheel was a 17x9 with a -12 offset. no spring rub at all...youll be fine
Discussion Starter · #5 ·
I also have a leveling kit and the truck sits pretty high right now. It seems like I could go a bit bigger and not have a problem.
Tire size will be fine. As Recon posted, he had wheels with that same offset that fit fine, so you should be ok as well. As for using your current lug nuts, it depends on the new wheels if they require the acorn nuts or not.
· Registered
Yes, they will work.
You will need 14x2.0 acorn style lug nuts.
4.5" BackSpace is what you want on the 99-04 trucks.
Offset is the distance of the WMS in relation to the true center of the wheel.....so go with a 12" wide wheel and you'd have a -51mm offset, but still have 4.5" of backspace.
· OBS junkie
If I decide to get them I will certainly do let you guys know how they are.
After thinking about that today they may make good sled pulling tires. Just consider that the Trxus STS & BFS K/O are both good sand tires without a very good bite. So who knows in 2-3 years we might start seeing them on the track.
Discussion Starter · #12 ·
Do 06 fords have locking hubs on the front wheels? I have been looking at these rims and not sure if they will work because my fronts have the locking hubs and it seems that 06's dont. Can anyone verify this.
· OBS junkie
All of the Superdutys I've seen have them. I was looking at the new 08s & you can get those with lock outs & a manual transfer case.
· Registered
ya they all have lock outs. all xd wheels caps are held on with i think four screws.... just need an allen wrench
· Oooo, White Lightning !
Those are the same ruims I want.........I wanna see pics when you get them
1 - 17 of 17 Posts
