1 - 5 of 5 Posts
Just had a complete rebuild, went to fire it up and i had no high pressure oil. My buddy at ford gave me some blocked off stand tubes to try to find the leak. one of which has an ico sensor in it. My left side holds pressure fine, but my right side (passenger) doesnt. I replaced o rings today and tested, still no pressure building on that side. the injectors are all okay, no visible leaks and i cant hear a leak. The tops still have their retaining rings and arent blown out? anyone have any sugestions??
Diesel Sled Head
Dummy plugs or standpipes? STC fitting? What year?
It's an 04 dummy plugs o rings good no leak there. The stand pipes are holding so I know there isn't any leaks there. . I just gave up for the night guess I'll try tomorrow before a .308 mysteriously ends up in the block
Well I found the problem the dummy plug on that side got switched with an actual stand tube plug so oil was running back into the case on the right side, never thought a motor builder could be so incompetent but on the bright side she's running
1 - 5 of 5 Posts
