1 - 6 of 6 Posts
it's an 02 05 08
just bought some new 05 f-250 badges for my 02 what is the best way to go about removing the old ones and installing the new ones
Lead-Don't follow.
Hair dryer and fishing line. Heat it up and slide the fishing line between the emblem and the fender (or tailgate) slowly working through the foam tape. Once the emblems off, use some goo-gone or other paint acceptable cleaner, get most of the rest off.
Put on the new ones, take pics, post, and you're done lol
Tonka Truck
I don't know if there is a difference between the 99 and 02, but it isn't just double sided tape. There is actually a hole in the fender and the back of the emblem has a piece that goes into the fender. Not that the hole in the fender will matter since you are replacing the emblem, but when the fishing line stops don't think you need to pull harder to get through the tape!
Lead-Don't follow.
Great point! Forgot the mounting studs. All 99-07 fenders have them. You'll need a plastic puddy knife to help to gently pry the emblem in the center sections.
what would you do to fill the hole without going all out and repainting or is it not really possible?
use it for your nitrous purge nozzle ;)
1 - 6 of 6 Posts
