1 - 5 of 5 Posts
Anyone familiar with the Clifford Matrix 50.7x that can help me out? If not are there any good forums to get some help with the remote start? Having trouble with mine and can't figure out what I'm doing wrong. Thanks
When I try the remote start I get a "Remote Start Error" message on the key fob. The ignition doesn't turn on, and it doesn't try to crank. When I look through the install instructions it says to look for the parking lamps to flash and this will give you an error message for troubleshooting. Well I never get the lights to flash when this happens. Went back through and checked all the fuses and connections, haven't come up with anything there. Did all the programming to set the functions up. I think I'm doing something wrong, but can't figure it out. Truck is an '06 F250 BTW.
PSN Mega Miler
I installed mine on a 2002 so its a bit different and I never programmed mine. Just wired it up and used it :D
What did you hook to what? What diagram did you use to know what wires to hook to?
you could call tech support
1 - 5 of 5 Posts
