1 - 6 of 6 Posts
Where can I find the bolt sequence and torque specs for installing the intake manifold? Also, the inside of my intake is completely covered with soot. 220,000 miles of it. I want to clean it but not harm the aluminum or machined surfaces. I have a couple of days to do this. Should I send it out to a shop? Thanks.
I put my intake manifold in a large bucket full of purple power, ajax, dish washer soap, and one other cleaner I forget, for 5 days. I sprayed it with a hose here and there durring the 5 days to remove what the cleaning solution loosend up. It came out very clean.
check all data........
as far as cleaning it, my friend put mine into the parts washer at work for a bit, came out looking really good!
Hood Rich
just make sure you install the intake gaskets with the knurles facing up and towards each other,on the inside.... I use 2 bolts on each side to hold the gaskets to the manifold while dropping it in
Thanks lenzhotrod, that is just what I needed. Printed and in my truck binder.
1 - 6 of 6 Posts
