1 - 5 of 5 Posts
Just wondering if anyone is having the same issue. I just got IDP's new tunes a couple of weeks ago but I got the new ford flash in june.The truck seems to buck after shifting into overdrive so I have to let off or the reduced engine power light comes on.Eric said that ford updated the flash because it was too sensitive but ford won't reflash it for me.They said its already done and they don't know anything about the updated flash.
StackinChipsLikePringles
Well thats your problem and try a different dealership because the updated flash was released in late july
Ok reduced engine power came up again and I got the following codes.p1000,p2610,p0234.I have read that the p1000 is nothing to worry about.The p0234 is something about overboost and p2610 is ecm,pcm,internal engine off timer performance.
Still tells me it is due to your flash
Please return your truck to the stock programming first, then read the strategy. Email me your PCM Part Number from the read strategy screen. That will let me know which version of the OS you are running.
Thanks.
1 - 5 of 5 Posts
