1 - 12 of 12 Posts
Lubrication Addict!!
When I bought my 01 F250 from the previous owner, the rearend didn't have a rear sway bar under it.
1. Was the Rear Sway Bar on Option?
2. Would a Rear Sway Bar help handling during towing?
3. Any opinion on make of Bar to look at?
The reason I asked... Is I see alot of older PSD with rear sway bars as well as newer models. And after changing out my front sway bars bushings with Energy Suspension polyurethane, it really firmed up the front end, and handling was night and day... so I figured what a rear sway bar would do for the rear end... Unloaded and Loaded?
Any Thoughts or Advice would be appriciated
Thanks
Attention Whore
Get one...period.
One of the best suspension mods I did. You can usually grab them from a junk yard for about 50 bucks with the axle brackets and end links.
F350 Balla
Are the sway bars the same for the gassers and diesels? Will an OBS bar work?
Reason I ask is because there is a gasser F250 at the local yard, but I dont remember if it had a sway. I dont think my 350 does, will have to double check.
OBS will work
I'd like to put one on mine too. Will they work if your truck is lifted?
Yes, just make the drop links longer if needed.
Great thanks.
"Miss me yet" George Bush
The X's did not come with them and you don't need to look far to find issues with them towing, it is a great addition to have if don't have it. Easy install won't take long at all.
Village Idiot
i plan on changing mine (front ) and adding to a helwig
larger and better
Back in Black
I have one factory and i cant notice is doing any good. i think i need to replace all the bushings. where did you gett the polyurithane ones at?
Mine did not come with one either and I put a Helwig on. It made a nice noticeable difference.
1 - 12 of 12 Posts
