Anyone done a rear main seal? I changed mine and i dont know if ive done it correctly. Fact, im almost possitive i didnt. Its leaking. So i pulled the old one off. Pryed the ring off, cleaned the rtv. Reaplyed the rtv, left the seal together on the ring. Slid it on the crank. Took a rubber mallet and went around and around untill the ring was all the way on the crank. Then took the flexplate and bolted it on. Now shouldnt the spacer seat the ring the rest of the way? Im aware they do make a tool for this. Does this tool set the ring farther. And if so how much?
