1 - 7 of 7 Posts
Hey guys I just did a 3inch rsk on my 95 f250. I basically followed what brad did for the rear and put 5inch tapered ready lift blocks in the rear. Now when I take off I get a driveline shimmy. I have a extended cab longbed so I am assuming I need to shim my carrier bearing to take bring everything back in line. My question is how thick of a shim do I need or is it going to be a trial and error thing trying different thickness shims?
Waitin' on 500
i think rule of thumb is 1/4'' for every inch raised.
You will most likely have to space down the carrier bearing 3/4's of an inch and put in a 5" non tapered rear block. You're pinion shaft rotates up when you throttle on it. It should be a few degrees on the low side as in the pinion shaft is closer to the ground. A friend of mine just went through this.
STILL LEARNING
By shimmy, do you man the rear axle is moving side to side, or that you feel a vibration? under acceleration?
If a vibration under acceleration, then you are experiencing axle wrap. I fixed mine with traction bars. no more vibration under acceleration
I mean when I take off I feel a shake but its just taking off from a stop. When im going at speed its fine.
STILL LEARNING
Traction bars will fix that. The added leverage form the 5" block is why you feel it. It now wraps the springs
1 - 7 of 7 Posts
