well i herd its the ford thing to sag in the rear well i wanna fix that wat do i do also i want to get larger rims and tires im running 35 right now and want to go to 37 38 mabe wat can i fit
What kind of lift kit do you have ?? blocks or leaf springs in the rear, mine doesnt sag at all !! maybe your springs if yoiu have them are bad or your front end could be sitting a little higher as well it could mean alot of things.
well honestly i bought the truck like it is lifted no reports on how it was lifted how much andthing im acctully guessing 6 inch and it is leaf in the rear
The stock 250 block is 1 7/8" a 350 is 3 3/4". Park on level groung and measure from the ground to the center of the wheel well at all four wheels and that will tell you how much sag you have front to back and side to side. From there the measurments will tell you if you need new springs.
ok from the driver seat looking foward the front left is 47 1/2 inches the left rear is 46 1/2 inches the front right is 47 1/2 inches the right rear is 46 1/2 inches so wat should i doo i have no clue
Did you measure the block most lifts still use the stock block If you have the 250 block 1 7/8" just change to the 350 block 3 3/4" and some longer u bolts. You are only an inch lower in the rear and it is the same side to side so I dont think the springs are bad.
