1 - 7 of 7 Posts
· you want some of this?
Anyone got a link , or info, I need to find the rear end info for my dads f-450. Need to order the parts for rear diff.
35 spline, or 37?
I have vin #
1fdxf46f7xec84719
99 f-450 cab and chassis.
Thanks guys!
Don't think you can get that info from the vin. May have to get someone to look it up from the numbers off the tag.
Well, I could go to the shop and check the rear end tag, but didnt want to drive up there again today. Oh well, thanks anyway. Guess it'll have to wait till tomorrow.
Wasnt sure if you could get it from vin or not.
· Registered
Does the truck still have the door sticker? If you do the axle code on the sticker is easy to decode. The last 6 digits of the vin are the build code, which give the build information, S/N, warrenty code, etc.
· Limp Member
Open the drivers side door. Look down low on the door jamb of the truck about shin high of your right leg. Just below the bar code on that tag it will say "axle"
31 - 3.73 non-limited slip, F-250/Excursion
C1 - 3.73 limited slip, F-250/Excursion
32 - 4.10 non-limited slip, F-250
C2 - 4.10 limited slip, F-250/Excursion
33 - 4.30 non-limited slip, F-250
C3 - 4.30 limited slip, F-250/Excursion
36 - 4.56 non-limited slip, F-250
C6 - 4.56 limited slip, F-250
41 - 3.73 non-limited slip, F-350 (single rear wheels)
D1 - 3.73 limited slip, F-350 (single rear wheels)
42 - 4.10 non-limited slip, F-350 (single rear wheels)
D2 - 4.10 limited slip, F-350 (single rear wheels)
43 - 4.30 non-limited slip, F-350 (single rear wheels)
D3 - 4.30 limited slip, F-350 (single rear wheels)
46 - 4.56 non-limited slip, F-350 (single rear wheels)
D6 - 4.56 limited slip, F-350 (single rear wheels)
F1 - 3.73 limited slip, F-350 (dual rear wheels)
62 - 4.10 non-limited slip, F-350 (dual rear wheels)
63 - 4.30 non-limited slip, F-350 (dual rear wheels)
66 - 4.56 non-limited slip, F-350 (dual rear wheels)
F6 - 4.56 limited slip, F-350 (dual rear wheels)
81 - 3.73 non-limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
E1 - 3.73 limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
82 - 4.10 non-limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
E2 - 4.10 limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
83 - 4.30 non-limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
E3 - 4.30 limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
86 - 4.56 non-limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
E6 - 4.56 limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
88 - 4.88 non-limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
EW - 4.88 limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
G3 - 4.30 limited slip, F-450 Chassis Cab
73 - 4.30 non-limited slip, F-450 Chassis Cab
78 - 4.88 non-limited slip, F-450 Chassis Cab
G8 - 4.88 limited slip, F-450 Chassis Cab
75 - 5.38 non-limited slip, F-450 Chassis Cab
G5 - 5.38 limited slip, F-450 Chassis Cab
GW - 4.l0 limited slip, F-450 Chassis Cab
98 - 4.88 non-limited slip, F-550 Chassis Cab
K8 - 4.88 limited slip, F-550 Chassis Cab
95 - 5.38 non-limited slip, F-550 Chassis Cab
K5 - 5.38 limited slip, F-550 Chassis Cab
KW - 4.10 limited slip, F-550 Chassis Cab
75 - Dana 80, F53 Recreational Stripped Chassis (Motorhome)
95 - Dana 135, F53 Recreational Stripped Chassis (Motorhome)
Discussion Starter · #7 ·
Thanks for the info!
Parts are in the living room.
Wish I'd seen this before having to crawl under there and scrape paint, and dirt, for the tag number off the rearend.
1 - 7 of 7 Posts
