1 - 12 of 12 Posts
I need to get a new rear bumper, has been mucked up since I got the truck. I am interested to see what you guys are running for bumpers and auxilary back up lights.
Thanks
STILL LEARNING
I originally put a set of LED pop ins in the bumper but with the dually, it shines behind the truck and all i can't see behind the truck with the dually fenders.
I got a set of LED ATV lights and mounted them under the bumper. they work GREAT. I have them tucked up high enough so if I back into a snow bank or something they will not get destroyed. I have them angled out as to see next to the truck as well as behind. I bought a set for EVERY truck in the fleet, I just need to mount them. They are so high, you can't even see them
Brad that sounds exactly like what I want to do. Can you post a pic of how you mounted them. I was thinking off the receiver.
Are they on a separate switch?
STILL LEARNING
I mounted them to the supports that go out to the corners of the bumper. Them, the LEDs in the bumper and the LEDs in the stock location are all wired thru the factory back up light switch. And all 6 lights draw less then the stock 2 incandescent
Ok.. I was worried about them drawing to much and blowing fuses.
what kind of beam do they have Brad? spot or flood?
Truk nutz?
(Not a fan but to each their own.)
That is still one if the nicest looking truck.
Awesome pics. Thanks for taking the time Brad. Looks good! What did you use for frame paint?
STILL LEARNING
Floods. No pint in being able to see 100' behind the truck, I wanted to see 10' behind it
POR15 as prime and TSC Lo-Glare black as a top coat
Truk nutz?
I think those truck nuts are made out of some kind of vehicle part or giant nuts for bolts.
I be strokin'
Brad, where did you get your lights from?
STILL LEARNING
Those are 3" nuts and they are from a 150' tower
Those lights I got from Ebay
1 - 12 of 12 Posts
