1 - 12 of 12 Posts
STILL LEARNING
I have a 97(cali) CCSb w 4:10s 5spd and RSKw SD springs and 315s. Has a DP tuner, 3" DP & 4" exhaust, napa 6637 What is the most realistic MPG that i should be seeing? I am getting about 13/15 city/hwy. Hwy is cruise set on 65
My old 97 RCLB 4:10 5spd RSK and 315s I could squeak out 19MPG on a all highway trip doing 65MPH
Since your cali has split shots(correct?) our trucks are somewhat similar, but i have stock suspension and 285's. When i went down to Unlimited Diesel it was 2.5 hours on back-roads running 50-60, and playing a little if i got bored. I averaged between 19-20 mpg's there. Coming home i ran on the highway from 70-90mph in rush hour traffic at times, and got 16.5. City driving i've seen it as low as 13.5 and as high as 17ish with my AD's.
Keep in mind i have an injector not firing, leaky up-pipe gasket causing the turbo to not lite until 2k RPM's, and a tranny that was going out. And i'm a teenager, so i don't drive it easy all the time. LOL
I get about 14 average. i could easily do 16 if i drove it nice. Im going on a 1000 mile road trip this weekend, going to try and keep it to the speed limits and see what she'll do. I have a 95 CCLB with 285s, 3.55s, auto and 160cc single shots.
i have a F-350 95 RCLB E40D, w/ts chip set on extreme, IC, and 3.55 gears, running 235/85r16's. last trip i made was roughly 160 miles and i got 19.5 mpg.
I'll take one of those!!! I get roughly 13MPG, but I am running 350's on a stock truck I am in the hunt for some stock rims and tires.
Seems a bit low to me.
I'm getting 14 mpg out of my 97 F350 E4OD 4x4 4.10 6" lift w/ 38's 6637 4" exhaust and a Banks 80hp chip (and ya the mileage has been adjusted for the tire size/gearing). 100% city.
My 97 F250 stock (3.55) 265/75/16's is getting 16.5 mpg 75% city.
Davey B
Truck in my Sig was getting 17.5-21.5mpg hand calculated with 2'' of lift, 285's, auto, straight pipe mbrp exhaust and tymar. thats not babying it, but not beating the fuk out of it either. im in the process of adding hybrids, tunes, an lift. i can let you know what it changes to with the new set-up in 2-3wks if you want.
I get about 14 towing a 6K travel trailer @ 55-60 on mostly Interstate; 17 towing a utility trailer and small tractor @ 55-60 on mostly Interstate; 21 solo @ 70 on mostly Interstate.
City driving has too many variables for steady measurements, but probalby about 14-15.
This with a 96 F250 auto with 3.55 axle on an extended cab long-bed loaded with camping equipment. Mods include round drop pipe, Tymar intake.
1 - 12 of 12 Posts
