1 - 6 of 6 Posts
don't play well w others
2 wheel drive yes, 4 wheel drive no
It seems the 150 arm and 250 arm have different part numbers one ending with an A (250 IIRC) and the other in a B (150). All other numbers are the same. The reason I'm wondering is that all I can find are radius arms for a 150 and not 250 2wd. Mine is bent after the wreck and need a replacement
Fantastic! You made that easy I was struggling to find one it seemed like. Do you know if they are specific to which side or can you use it on either the driver or passenger? I assume you can on either
1 - 6 of 6 Posts
