1 - 4 of 4 Posts
My radio in my truck wont turn off. I went to church this morning and everything was working fine. After we got done eating lunch I went to leave noticed my radio was still on. I need some advice/guidance to what could be causing this to happen, thanks :confused:
PETE ENGR PSD
I would check your acccesory relay first.. Its generally a culprit. Try swapping it with the one above that. Or it could be a door switch, do your lights stay on at all? My vote would be accesory though.
I agree accessory relay is most likely typically caused from a failed door latch switch or bad relay it's self bt can be caused by a malfunction of the BCM. Locate the relay and pull it out see If it goes off. Than diagnois from there. Try opening the passenger side door as this should also send the shut down to the delay relay.
1 - 4 of 4 Posts
