1 - 7 of 7 Posts
so im putting my truck back to gether finally and getting pretty close to being done but i got all mixed up and they got bent all out of wack now
on the fuel lines goiing up to the fuel bowl whick on goes where (i got them hooked onto the fuel bowl and ran down already) but i dont rember if the one on the top or the bottom of the bowl ties into the fuel line wrapped in blue on the frame.?
in the stell line, where the 2 lines were conected together to gether with that bracket piece . so how during the motor swap it got bent and broken right their. can i take it to the hose store and just keep the ends and have them make the rest a rubber line? i would rather do that
Fuel pressure from the fuel pump is not infinite. Cut the line clean and square, then push some high quality fuel injection line over the two ends. Double clamp the hose on each end. Flush the line with the fuel pump before you reconnect it.
1 - 7 of 7 Posts
