1 - 17 of 17 Posts
More Power Tim
Like to use the Scheaffers in my other vehicles but I'm currently using a high milage oil cause of the age and milage. Would like to stay with a high milage product. Can I get a 5w-30 full synthetic in a high milage formula from Scheaffers?
Thanks
I've always been curious what makes a high mileage oil a high mileage oil. My bet, it is a gimmick and any good oil is good oil.
Plain old Castrol GTX has kept my dads ranger going for 400k miles on the stock 2.8.
More Power Tim
Supposed to have additives in it that swell and soften the seals. When I started using it in my wife's toyota it helped slow down the valve cover leaks A LOT until I got the time and money to fix em. Has worled wonders on my OLD vehicles. Valvoline got a product of the year award several years back when they introduced the first high milage oil on the market. Soon everybody followed suit. Gives me a little more time between expensive leak repairs. I swear by it!
Stirn Again
My scheaffers pricing info is showing a 5w-30 in both synthetic and synthetic blend.
Its been awhile since Ive looked...but I have a feeling you're talking about oil that isnt rated for a diesel.
Stirn Again
Sorry, yes they do carry a 5w30 for cars and light trucks (not diesel rated though)
in the 9000 synthetic and also in the 7000 syn-blend
More Power Tim
I guess I should've clarified since I am posting on a diesel forum. Duh! Sorry guys. Yes, I am reffering to an oil for a non diesel vehicle. My other vehicles are gassers, wife's Toyota and daughters Plymouth.
the stryker god
in my old escort with 300k on it i used supertech synthetic 5w30. changed it every 4k. ran like a top when i got rid of it
anyone had any problems with the scheffers trans fluid in a 01 superduty. mine was running hot when pulling 10,000. going back to mercon v
flushed it like the other forum said and it runs cooler with mercon v, know just 2 more to do. wow pricey with no help from scheaffers
:doh:
:doh:
My bet, your trans was slipping. BTS says Schaeffers is to slick for a stock e4od or 4r100. They recommend good ole Mercon for a stock trans.
I havent used it but always heard really good things about it. Sorry wasnt much help.
Never had any issues. Sounds like you may have another issue.
Have you checked to see if your cooler bypass is clean and functioning?
If it gets stuck part open/part closed you'll have issues, but only when towing.
You can also add a friction modifier from lubegard to see if that fixes it. Lubegard 62005 M-V ATF Supplement : Amazon.com : Automotive
1 - 17 of 17 Posts
