1 - 17 of 17 Posts
i have a 2000 f-350 7.3 with stage one single shot injectors, my question is do i have to put equalizer lines on the fuel and the high psi oil or none or one of the two
yes i have a custom tuning for it but the equaliser.....i mean like to equalise both banks. like your fuel and your oil going to your injectors
I am not running that, and I have the 160cc AC injectors.
It's no different than regular injectors, and of course the "equalizer" lines are an option on them too, but not necessary.
Supercharged
I'd say they are more or less a waste of time and money, and a extra place to leak.
<<< THE GAUGE WHORE...
Ditto... leaks, drips, blow outs...
FORD..THE ROCK CRUSHER
Don't mean to Jack ......but what about fuel regulated return could that cause leaks too ?
Thanks
actually its less likely with the right kit but the benefits are much greater... fuel lines see 70 psi + - the HPX could see up to 3000 psi..
The Fireman
I ran a hpx line for a while but like others have said, they start leaking. Mine did, so its back to how it was and I can't say that I can tell any difference. It runs the same.
Village Idiot
Some trucks idle better, on a side note some big oil systems tie both rails together anyway.
And you will see an improvement with big oil even with a stock injector.
1 - 17 of 17 Posts
