I need to reseal and likely replace my oil pan. I also need to replace all the o rings in my HPOP and likely the lines. While its out I planned on doing the nicer fuel lines and HPOP lines. The radiator hoses need replacement due to age, probably the pump too.
Just did the injectors, glow plugs, harness, end plugs in the rails, ebpv delete with the new pedi stool and turbo exhaust housing delete, also replaced the bushings and o rings in the turbo.
I didn't use the yellow oem o rings under the turbo and under the pedi stool and might have leak there...similar issue with not loctiting the rail plugs (facepalm)
I am not interested in any power adders but I am interested in anything that makes sense to do while its out. Its an old project truck that over time Im going to make great again lol. It has 308k miles on it but good compression and seems to run great at the moment...just leaky and dirty.
Input?
Input?
