1 - 11 of 11 Posts
Harl
Whats the easyist way to pull the motor? thanks
-Cody
Harl
Discussion Starter #2
Bump.. Any one no.. Lift the cab? Take the turbo off ect? whats the eaist way?
Don't EFN worry about it
I leave it(turbo) on I pulled the water pump off and it came out real easy only thing I forgot to unhook was the damn pyro lead.............. Chit oh well bought another one. Bobcat (skid steer) knows no strain LOL!
Unhook batteries
Ok drain all fluids - remove oil filter
Unhook the electronics
Exhaust,IC tubes if equiped
motor mount bolts
bell housing bolts and torque convereter too.
Also remove the starter.
Im sure I forgot something but that should get you to thinking about it.
I pulled mine out with everything on it but it would be alot easier to take the waterpump off for sure. Very tight to get it all out in one piece.
:poke:
easiest way is to have someone else do it LOL
Dairy Mechanic
DZL JIM has a write up on how to remove motor. I can link it if you need me to.
Harl
Discussion Starter #9
You can pull the core support . I just did mine that way because I had to take it off anyway . It made it really easy only thing to clear is the crossmember , I did'nt even pull the hood .
1 - 11 of 11 Posts
