1 - 7 of 7 Posts
I have 12,000 miles probly a little less.
On a 100% rebuild.
New Injector cups were installed..
I have had the Injectors in question out 2 times prior..
Heres the story.
I just pulled the injectors to get them gone thru..
I pulled the oil drain plugs under the VG prior to pulling them.
Once I pulled the 1st inj. I hear a glug, glug glug...
So I stuck a rag in the hole.. thinking it was fuel and hoping to catch it..
Just went to put it back yogether and figured I would try to get the Fuel out of the cylinder..
So I stuck a small piece of hose to a vac. pump and started sucking out the cyl.
And Coolant started comming out....
Could it be a Cup pulled up when I pulled the Injector??
I tryed to measure to see if It pulled up but dosant seen to measure differant...
I am at a loss what to do..
I have te guy that built the motor comming over this weekend to change out the 2 cups that are in suspect...
Any Ideas...
Didnt have any coolant loss prior to pulling the Injectors..
Id appricate any advise...
Thanks'
John
Might be cracked right where an oring would zeal it when installed
Thanks for the reply..
I guess Ill see Saturday when We pull them..:eek:
It is the first two cyl. on the Driver side
At least its the easy ones
I had one come loose on me when pulling the injecotrs for the first time since 95' and all the coolent drained into the oil pan! i was not happy but i was able to just put the injector back in and torque to spec...run it...then re-torque it and no problems yet..
1 - 7 of 7 Posts
