1 - 4 of 4 Posts
The Unseen Mod
Found this last night might help some folks on terms.
VSS - Vehicle Speed Sensor
VGT - Variable geometry turbo
WTS - Wait to Start
CEL - Check Engine Light
WIF - Water in Fuel
HPOP - High Pressure Oil Pump
LPOP - Low Pressure Oil Pump
ICP - Injector Control Pressure
CPS - Cam Position Sensor
IDM - Injector Driver Module
IPR - Injection Pressure Regulator
PCM - Powertrain Control Module
TLA - Three Letter Acronym
PSD - Power Stroke Diesel
IDI - Indirect Injection
DI - Direct Injection
DLC - Data Link Connector
MIL - Malfunction Indicator Lamp (same as CEL)
GP - Glow Plug
GPR - Glow Plug Relay
TPS - Throttle Position Sensor
IVS - Idle Validation Switch
IAT - Intake Air Temperature
EOT - Engine Oil Temperature
MAP - Manifold Absolute Pressure
AIC - Aux. Idle Control
DTC - Diagnostic Trouble Code
EBPV - Exhaust Back Pressure Valve
EBP - Exhaust Back Pressure
DRW - Dual Rear Wheel
RCLB - Regular Cab Long Bed
SCSB - Super Cab Short Bed
SCLB - Super Cab Long Bed
CCSB - Crew Cab Short Bed
CCLB - Crew Cab Long Bed
CCDRW - Crew Cab Dual Rear Wheel
AT - Automatic Trans
AC - Air Conditioning
ABS - Antilock Brake System
BARO - Barometric Pressure Sensor
KOEO - Key On Engine Off
KOER - Key On Engine Running
DRL - Daytime Running Lamps
TTB - Twin Traction Beam
FPR - Fuel Pressure Regulator
CAC - Charge Air Cooler (also called intercooler)
5ER - Fifth Wheel Trailer
IC - Intercooler (also called CAC)
BTS - Brians Truck Shop (usually referring to his transmissions)
BIG OIL - Typically Twin High Pressure Oil Pump Setup (Terminator, Stealth, BTS)
Super Moderator
Added 1
WTS - Wait to Start
WIF - Water in Fuel
GP - Glow Plug
SRW - Single Rear Wheel
PSA
thank you...i was gonna make a post asking what all of them meant yesterday. awesome
I think this may be in the wrong forum...
HPFP-High pressure fuel pump
RR-Regulated Return
DPF-Diesel Particulate Filter
MM-Mini Me(230cc hybrid injector)
BB-Ball Bearing
JB-Journal Bearing
More to come. I may have double posted some... But I scanned over...
1 - 4 of 4 Posts
