Nope, reused the stock springs.Dan,
Just curious - when you rebuild your engine did you put in different valve springs?
Cj
I found cyl 7 had the injector pigtail fall out, most likely from me putting the valve cover back on, so that explains why cyl 7 failed.
Unplugging cyl 1 had no change on how it ran, so thats our culprit. All injectors were ejecting oil evenly, and all valves were working properly. I swapped the solenoid with cyl 5, and no difference. So I pulled the injector to put my borescope in there, but everything is so oily from pulling the injector that I can get a good look. I have my little vacuum sucker but I can't get it all.
I can see the valves, and they look fine. But there might be some marks on the piston, I just can't tell for sure with all the oil
