Got more work on the truck...
Track bar mount is made, mix of 1/4" and 3/8" Steel, kept it pretty simple looking, but fits perfect.
Installed for mock up. This is at full bump.
Clearanced the crossmember a little bit with the grinder. Might go a little more to get some more clearance, but I really want to make bump stops to prevent contact.
Clearance between track bar mount and diff cover. I have seen other manufactures make contact with the diff cover and/or the cover bolts.
Full bump with 35" tire installed.
Full bump, full lock, no rubbing in both directions.
So I pulled everything back off and welded most of it up. (In 107* heat I might add) So this weekend I'm pretty sure this truck will be on the road for test drives.
