1 - 20 of 53 Posts
After reading this and the army for the last 3 years after buying my truck, it’s time to dig in!
Truck is ‘95 CCLB 4x4 I found local in northeast Iowa. Had 244k on the clock when I bought it and passed the blow by test. There was zero rust on the cab... a miracle for a 22 year old truck in the rust belt. Did have rust on 3 of 4 fenders over the wheels plus the usual wear for the age.
Because I can!!!
Where are you at in Iowa? I'm over in the NW corner in osceola county
Sent from my SAMSUNG-SM-G930A using Tapatalk
These were taken shortly after purchase
Waterloo
Because I can!!!
Complete otherside of the state then! I dig the truck!
So first upgrade was headlights. Wanted separate low and high beams so that I could eventually add a diode and relay to get low beams to stay on with my highs.
Haven’t added the relay and diode yet but do have some LEDs in the lows.
Last August I installed PMFs 2.25” RSK with what I thought were V code springs... 2,600# per side. Just measured and it’s sitting 27 3/8” center of axle to bottom of front fender with a slightly positive arch to the springs. Wishing I would’ve bought softer springs but still a night and day ride improvement! Also got bilsteins from PMF and extended sway bar links from skyjacker.
201373
201374
Still have the original headlights, chrome trim rings and associated parts if anyone would like them.
Because I can!!!
I'm like 30-35 miles from there!
Just started my DIY e fuel and super duty front fuel tank upgrade...
Decided to take the beat up bed off for ease of install.
201375
201376
201377
201378
201379
201380
Gooseneck hitch and bed bolts were removed by grinding.
Almost forgot, did super duty UVCH upgrade and found 7 of 8 glow plug pins were burnt in the original harness.
Recommendations on how to rebuild the hitch?
I’ll get a picture of the angle iron that needs removed to fit F26e tank.
Got the super duty sending unit wiring plug re-pinned and added and added a dud wire to fill the hole in the plug left behind by the rep in. Taped back up then tucked back into the factory wiring split loom.
Used this thread for wiring reference.
  • Like
Reactions: Lt.Dan
Discussion Starter #14
201470
At the parts store getting fittings.
Discussion Starter #15
201471
1/2” draw straw for Bosch -044 pump. Interesting this pump is setup for 1/2” supply with 3/8” output.
Discussion Starter #16
201472
Fittings all assembled. I have a local fabrication shop bending 12 gauge sheet into a C channel to mount the filter bases and pump onto. Piece is 13” long and measured to fill the inside width of the frame rail.
Discussion Starter #17
Not sure of the technical term but the hydraulic shop where I bought the fittings called them aggressive barbs for the hoses. Rated to far more psi without hose clamps than the fuel system is regulated to.
The threads are all NPT and I put Teflon thread sealer rated for diesel fuel on the threads. It’s blue in above pictures.
Discussion Starter #18
@Lt.Dan Would you tack weld the nuts onto the mounting bracket before paint and assembly?
1 - 20 of 53 Posts
