1 - 20 of 35 Posts
"that guy"
i was just tryin to get a ball park figure for getting head studs installed on a 06 6.0l thanks for the help
Depends where you live and if you go to a dealership or a diesel shop.
In general, dealerships in major cities will charge you for a full headgasket job, which will run between $3,000 and $4,000. If you're in more rural areas, you can get them done for under $3,000.
Diesel shops have been known to charge less, bottoming out at about $2,000.
OrthoPro
I can get the job done with ARP's and an EGR delete set up for 2K here in Salem, OR. from the dealership (family owned-small operation with in house diesel shop and certified mechs) where I bought my truck from.
PETE ENGR PSD
I think I spent around $2000 with doing the install myself. That includes updated fittings, studs, gaskets, oil cooler rebuild, EGR delete, turbo recondition, etc.
A Ghost these days...
These guys are in Florida I believe.
Scab
What's the deal with your Avatar?
I got mine done for around $1500 from a local Ford dealer in Crossville TN.
That's putting arp's in, and an airdog II.
40 lug nuts
Doug is definitely a great choice. If he's not able to do it for whatever reason and you're willing to drive up to Tampa, shoot me a PM. There's a shop near me that I'd highly recommend.
<-MONEY PITT!!
around $$$2000 Make sure your heads are flat:poke:
<-MONEY PITT!!
Yep...Kinda funny how people blame the studs And its always the heads LOL First thing i say when People start talking about there 6.0 thats studded and still pukes...Did you check the Heads...NO...Well theres your problem!!!
2Cruel
2100 and up depending on what options ya want while your in thier,
Having the heads checked is a must (fiigure on having them decked $$)
Valve seats are usualy cracked (figure getting them machined)
While your that deep egr delete and oil cooler only makes sense
05+ trucks need the updated y on the oil pump
So it can add up pretty quick!
Travis
<-MONEY PITT!!
The truck is a-ok as it is. I just want to get some ARPs for piece of mind and SCT.
I would still have them checked...Hate to have to do it twice...Plus they are already going to be off
PETE ENGR PSD
Is it common for the seats to be bad? I had each valve checked on mine and all were good (both heads), take that back, two were questionable.
Don't mean to de-rail the thread.
Right. Skip out on $3-$500 to get the heads totally checked out and your already deep another 2 grand just for getting cheap.
1 - 20 of 35 Posts
