1 - 9 of 9 Posts
05 6.0 no studs, egr deleted
Pressure is getting into the degas bottle with no loss of coolant, what are y’alls thoughts?
It also takes a while to get to operating temp and stumbles when you first get her going from cold, after the temp gets to about 100 degrees stumbling stops.
New injectors and 278111 on the clock
Discussion Starter #2
Also did a exhaust gas test from the degas bottle and it came back negative.
Diesel fuel in the coolant..... injector cups it appears to be
Fuel in the coolant is more likely to be a cracked head. BPD makes a repair kit. But good luck. And you probably have a blown head gasket with the mileage on the original bolts
"resident smarty pants"
+1!!
It isn't the cups on a 6.0L.
Typically the crack is at the #3, #5, #4, or #6 cylinders (by the injector hold down bolt holes).
Ya I am figuring it is..... this is a customers truck and I have an allowance of 1k for work.... soooo it’s not gonna get done lmfao!!!!
+1!!
Bismic1, how prominent are the cracks by the hold downs? This is the first time I have ran into the issue of diesel fuel in the coolant.
Unfortunately it isn't "rare". TSB 08-23-8 (primarily indicates a crack in the head)
To detect where the cracked head is when you have fuel in the coolant:
You need to put dye in the COOLING system and run engine for a few minutes to allow dye to mix with coolant. Use a good degas cap so system will build pressure. When turning engine off, cooling system pressure will cause coolant to bleed into injector bore on head that is cracked, you will be able to identify (with injectors removed) which head is cracked with black light. Fuel also shows up a light blue with blacklight, but you will be able to differentiate between fuel and dye in coolant.
https://www.accuratediesel.com/shop/279.html
DTR stated that the passenger side is the most common, but I would say it can be on either side.
BulletProofDiesel sells a repair method also.
https://www.bulletproofdiesel.com/BPD-cylinder-head-repair-tool-ford-6-0L-p/cylinder-head-repair-tool.htm
https://www.google.com/search?q=BPD+cracked+head+repair&rlz=1C1CHBF_enUS722US722&oq=BPD+cracked+head+repair&aqs=chrome..69i57.6789j1j7&sourceid=chrome&ie=UTF-8#kpvalbx=1
1 - 9 of 9 Posts
