1 - 15 of 15 Posts
ok, so after I finished installing gauges in my truck the power windows just stopped working. I checked 20 amp fuse for the power windows and it is fine. Also, I am using the fuse panel to power my gauges and they work fine. I'm stumped on trying to figure this out.
Fixing Broken Stuff
Is there power to the switches?
I don't know if this is helpful for your year model but I've read some forums that talk about the module that controls the windows is located under the dash and that it's common for the windshields to leak and damage this module. I have a 2002 that has intermittent issues with the power windows but so far they have started working again.
The only thing that works on the master switch is the power locks but on the passenger side the switch will only unlock not lock. So I'm guessing that means I'm still getting power to the switches right??
do you have an alarm with remote open?
obs addiction
99-03 have the gem module that has the windshield leak problem causing damage. Obs trucks don't have one.
would this shut down your radio as well? my windows and radio lose power at times for several minutes. 2002
Sorry for the hijack. free bumb? :D
STILL LEARNING
I a going to guess where you tapped in for your gauge power you screwed something up. Maybe now it is not making a full connection to the window circuit
obs addiction
Yes, I had a 01 that needed a gem for same reasons. Good luck finding a new one ford stopped making them. I had to pay for one to be shipped from Alaska. Sold the truck shortly after. I'm pretty sure all this is in the super duty section......
obs addiction
:whs: Brads prolly right, he's always right :poke:
Yea but I even unhooked the gauges from the truck and the windows still did not work… All fuses in the fuse panel and distribution box are fine.
Discussion Starter #14
All windows do no not work and I checked the lock button too.
STILL LEARNING
Sorry brain fart last night. The power windows do not use a Fuse. they use a circuit braker
Also, if you bent the pin where sit goes buy tapping it with the gauges, it may not be making continuity even though the circuit braker is still good
1 - 15 of 15 Posts
