1 - 5 of 5 Posts
Discussion Starter #1 (Edited)
hello there, not sure if I'm doing this right cause I'm new but here we go. I have a 2005 f250 6.0l that I had some steering problems with so I replaced tie rod ends, steering stabilizer, steering gear box and power steering pump. Im having issues turning the wheel when im siting still, is this normal? I think I bled the system correct, had the truck on stands and rotated the wheel lock to lock like 30 or 40 times. Thanks in advance! 156000 miles, 35in tires
Try it with the wheels off the ground? Frozen ball joints can be an issue also. Can disconnect the drag link and stabilizer and try turning by hand
Off the ground when I was bleeding it, it turns great with one finger, as soon as I set it down, it locks up until I give it throttle or start to roll
1 - 5 of 5 Posts
