1 - 6 of 6 Posts
About 7 weeks ago I was making a u turn and hit a pothole. My high pressure line blew out of the pump. I replaced it and now I'm having a bad leak where the line plugs into the pump. I've taken it off and put it back multiple times. With and without Teflon. Am I not supposed to tighten this fitting all the way? The washer where it goes in the pump is where I think my problem is. I think I read that over tightening can booger the washer and cause leaks.
sounds like the nut in ur PS pump is messed up( where the High pressure hose connects to). I think it has a flair fitting on the hose, SO Teflon wont do anything
My truck has a build date of 11/97 so it has a o-ring fitting rather than a flare. I bought a new I/ring and it still shoots out. I may try a new hose and the piece the female that screws into the pump.
No you're not supposed to overtighten that fitting. The line should be able to move with it tight.
That part is still loose. The leak is from the threads where the hose screws into the p/s pump outlet.
I talked to the guy at the auto parts store and he thinks I missing an O-ring. How many should there be ? Is there one on the end that goes in the gear box?
1 - 6 of 6 Posts
