1 - 2 of 2 Posts
When I'm slowly turning it becomes difficult to turn. I just had my tires rotated and it's only been since then. Then fluid was a little low so I topped it off. I have 37" tires on it but turned great before.
Fuel it up again Dummy
Try changing the fluid on it, there are video,s on you tube to make it easy. Basically you pull the 3/8 hose off up on column and put your own hose down to a 5 gallon bucket and have some one fill as you turn steering full lock to lock and at the same time press the brake on occasion. I bought 4 qts of the ford fluid it was under $30.00 to do and is a good idea to keep pump and hydro boost healthy.
Good luck Oh one more thing its easier if you jack front wheels up. It will help I am turning 38s and yea its workin it. Easy Job...........
1 - 2 of 2 Posts
