1 - 8 of 8 Posts
hey guys,
Can you powder coat the compressor housing to the turbo? Not the exhaust housing.
Powder coating will turn crispy if you bake it to long or at a lil higher than it's cure temp. (My basis for this is cheap harbor freight powder, so take it for what it's worth.) I would think that it would be to much heat at the turbo.
You could probably have it ceramic coated. Cheers!
whistle tits
Compressor housing shouldnt get hot enough to bother the paint. I've personally spray painted a few turbos compressor housings, and it has held up for years with no chips or anything
Thanks for your replies.
'05 Excursion
There's a company that use some kind of process to put a design on the turbo compressor housing but I don't recall the name. Liked the camo example they had.
Sent from AutoGuide.com App
hydro coating?
I painted my turbo compressor cat yellow and had turbine ceramic black.
only been a few months but yellow stilllooks perfect, not so much the black IMO
'05 Excursion
1 - 8 of 8 Posts
