1 - 3 of 3 Posts
PSN Been daer dun it!
I have been having an issue with a sticking turbo, and low boost. I removed the turbo and split it. Not much soot or corrosion, but seem to be some wear. Is this normal? It has a lot of wear on the vane ring wear the piston pin moves the vane ring. Both the pin and Vane are worn. Could this be the cause of my problem? Is this require turbo replacement? Can you get these parts, or is this normal. I believe this is the original turbo. 122k miles.
Lenz, I appreciate all your help. Found the ring on Ebay from Ford Diesel parts. I hope this fixes my problems. Just bought the truck. Have drove it for a few days...Made a great price on this one owner truck...Just getting the normal wear stuff fixed I guess.
1 - 3 of 3 Posts
