21 - 35 of 35 Posts
I just took measurements to a local weld shop and had them make a cable with 0 gauge weld cable. Super flexible, and has lasted 8 years without issue so far. Cost me about $100.
Hi,
I custom made all new battery cables for my 2002 Ford F-250 7.3
I completed the Big 3 Upgrade. I have included a link to a YouTube Video related to this upgrade.
I bought all the parts on Amazon.
I also bought a hydraulic press for crimping the terminal connectors on the cable. The press was $70 dollars. It is well worth the money.
If you would like a parts list and pictures of the finished job, let me know.
Good Luck.
Need to replace the positive cable on my 7.3, but can't find ANYBODY who has one in. Anybody got a "secret supplier" I can buy from?
I got a Motorcraft cable from Rock Auto about a year ago. Gonna change it when the batteries die, which will probably be soon.
Administrator
Cut the terminal off and solder eyelets to it then use a military style terminal. Easy peasy.
Discussion Starter #28
Whoa! That sounds awesome. It's only the one connector (Passenger side pos) that's a problem. I don't think my basic soldering iron would do the trick. Would a "medium duty" soldering gun be enough, or is it more of a specialty tool. If it does require something special, where could I take it to get that done. That definitely seems like the least expensive option.
Administrator
Yep a blow torch for doing plumbing. It takes a ton of solder also. Just a public service announcement. Batteries are flammable and will explode. So if you use the torch in the engine compartment pull the batteries.
Discussion Starter #31
Ahh. That makes a lot more sense. I couldn’t figure out how an iron would transfer heat through enough of the cable to work. Standard rosin core solder?
Administrator
I believe 1/0 to the starter and 2 gauge to the other batt.
21 - 35 of 35 Posts
