1 - 20 of 30 Posts
Sorry to drag this topic through the mud yet again. But I don't want to spend any money extra, or miss a vital gauge. I only get "play" money once a year, so I have to make it count.
What I currently own: Scangauge II (if USPS will ever deliver anyways)
What I plan on buying: 4 pod Glowshift pillar mount with gauges, Stand-alone voltmeter
Gauges I want inside the pod:
Boost: 0-35 psi
Exhaust Pyro: 0-1500 F
Fuel Press: 0-100 psi
Oil Pressure
All 4 gauges are $275 before shipping, with the promo code "autumn11" applied, there is a $27.60 discount. So I'll pay $248 for 4 gauges, pod, and fuel rail adapter. Glowshift success rate seems pretty good lately. I figure if they last 1-2 yrs, I'll be happy.
The Scangauge will be used to monitor FICM Volts, ECT, EOT, and ???. I'm fairly certain I can flushmount the voltmeter into the dash somewhere...probably by the power pedal switch.
What am I missing? Help me make an informed purchase. Thanks
really?
I see a bunch of guys advising to avoid exceeding 1200F. thought a 300F buffer would be sufficient.
EOT would be something good to keep an eye on IMO.
hillbilly
Agreed, try not to exceed 1200 sustained. During short runs(1/4 mile or stoplight run), mine easily maxes out the 1600f guage. Just letting you know I wish I had bought a higher temp rating. BTW those guages look very sweet.
Discussion Starter · #9 ·
crap...thanks for the input. I guess accuracy of 100F vice 25-50F increments is acceptable as long as I know how high (roughly) I'm getting.
I don't hot rod her often though...hard choice because I'd like to keep the gauges in their max accuracy sweeps which is about 1/4 to 3/4 of their overall range.
Sorry...Blame it on third shift.
Next.:pointlaugh:
NP, I was/am doing a 3rd shift myself right now :postwhore2:
the scan gauge should be able to monitor volts.
it does, but for $25, the voltmeter thing is kinda neat. and it frees up a Scanguage position. I think it'll look kinda cool on the dash
I'd get 0-60 psi boost can peg that 35 quick
Discussion Starter · #11 ·
I thought the trucks went into overboost at >30 psi?
I think I've seen max of about 24 psi so far since buying. How high a boost are we talking once I get my SRL Tune?
Eric from innovative actually some of fuel back and timing back but I still can hit 35 psi
i like to party
You have the scan gauge to Monitor the necessities through the PCM (FICM, Volts, EOT, ECP, ICP) thats good
Analog gauges I would have to recommend Pyro, Fuel Pressure, Low Pressure Oil Pressure, Boost (stock ones a joke and tunes fool the PCM for heavy fueling so the reading is not usually accurate when tuned)
HPOP on these trucks usually are never a problem granted 03-04 pumps had their share of issues it still doesnt really need to be monitored, and thats what the ICP on the scangauge is for
Discussion Starter · #15 ·
where would i tap into the LPOP? I've seen some guys thread a fitting into the top of the oil filter cap. was that for the LPOP? I've also seen billet caps for sale with the fitting already installed
tapping into the oil filter cap will only get you the EOT.
<<< THE GAUGE WHORE...
I would get Isspro EV2's and stick with a 2000*EGT gauge... 40psi boost...
sorry for the derail but csipsd would a 7.3 need a 2000egt gauge aswell>>??
just put glowshifts in my truck, i dont know if it will be an issue on yours but i had to put a 45 deg fitting between my test port and fuel press guage because otherwise it was rubbing on my top rad. hose and i wasnt fond of that but other than that the gauges seem to work pretty good i went with boost 0-60 psi pyro 2400 deg fuel press and tranny temp.
1 - 20 of 30 Posts
