1 - 5 of 5 Posts
Curious what the difference between a stock hpop and performance hpop?
JGman141
Performance hpop's flow more volume of oil than your stock one, in turn this means you can put bigger injectors in and not worry about dropping icp. There are limitations to the injector sizes that can be supported though.
Discussion Starter · #4 ·
thats what i figured i just wanted to make sure.. stage one injectors would be fine with an adrenaline pump then..
Still learning
all the "stage one" injectors I've seen would work fine with a stock hpop
1 - 5 of 5 Posts
