Driving back from from home depot and pulled up on a red light when light turned green i Accelerate it and I noticed it would go as I usually hit the gas. it literally felt like when you pull out of your drive way and you just put i in drive with out hitting the gas I would not accelerate at all and as I was pressing on the pedal to see if something was stoping it all I got when I let off was a weird clattering noise from the motor for a second and went back to normal engine idle. I thought it could've been the fuel tank pick up screen sock filter (REPLACED) that's wasn't the problem I also seen when pulling out the unit the big filet was broken. So maybe theirs air in the system and need to bleed out 🤔 . Then my neighbor said it could be the pedal sensor my truck has 315k miles so I hope thats it inorder it and it comes in Tuesday. If anyone has experience these symptoms please let me know how yiu went about it thank you in advance.
REPLACED PEDAL SENSOR
No progress still rough start, bad idle, bad acceleration. If anyone has had similar symptoms let me know thanks
