1 - 7 of 7 Posts
PSD & IDI WARRIOR
I have a friend that has an early 99 F250 PSD. He bought a new TS 6-pos chip and we installed it today. He is a trained mechanic of 20 yrs exp and I went thru Lincoln Tech myself a number of yrs back and it is far from the first one that we have installed. We took all the appropraiate precautions and the likes. The truck ran fine before the install. Now it will not run with or without the chip. His Genesis EVO shows the PCM is dead. I have an '01 E450 SD with a PSD and an E4OD. Can he try this PCM in his truck???????
Sounds like you fried the PCM when you put the chip in. If you don't clean the contacts properly, it will fry the PCM.
Pre-K
Does anyone know if there's a way to get these rebuilt? Or when replaced, is the old one saveable or garbage? Thanks.
Edit - Didn't think a new thread was worthy of this one question.
Demon Dually
Old one is now scrap metal or a good paper weight.
1 - 7 of 7 Posts
