1 - 13 of 13 Posts
<---Peggy Sue
i just bought a used ts 6 position with a pmt code and i put it on my truck and it ran for about 5 min then shut down goin down the road. i then pulled it out and returned it back to stock and it ran fine... just wondering if that may have been a freak accident or if that means i have a different pcm code. it is the truck in my sig
are you sure the chip did not come loose in the pcm
<---Peggy Sue
idk it might have
If the PCM code is of the same family, then it should work.
For example,
You couldn't use a PCM code of PMT3 in a TDE1.
you could use a PMT3 in a PMT2 PCM.
Village Idiot
prob came loose, did you tape it in?
pcms can be close and still work fine..ie
i used to run an 01 pmt pcm in my early 99 with nvk tunes.
not ideal i am sure but worked great for me at the time.
<---Peggy Sue
no didnt tape it in but i already sent it off to wildman to be burnt
Village Idiot
when it comes back put a piece of tape on it to keep it from shifting.
<---Peggy Sue
will do thanks alot man
<---Peggy Sue
Discussion Starter #9
well i got my chip back and i cannot believe the difference it made in my truck from my diablo chip... Tony Wildman is a badass:bowfast:
<---Peggy Sue
:doh:eek:nly one problem lol 2 broken u-joints, a busted up drive shaft and a mangled pinion yoke:doh:
Village Idiot
ouch..did that in a dam rodge 1500, only added a rear end to that.
decide to roll on home in my new front wheeldrive truck.
that is how I ended up with a powerstroke.
<---Peggy Sue
lol ya i put a rear end in it about 6 months ago hopefully ill run out of weak links
1 - 13 of 13 Posts
