1 - 5 of 5 Posts
So i have a 2000 f250 psd. The passenger side electric window has began to stop working randomly. So i'm assuming a component needs replacing. Which one would it be, the power window motor or regulator ?
PSN Pretender
More than likely your issue is in the wiring.
Check the wires in both front door jambs for any sign of cracking/ fraying. You will have to wrestle back the rubber boot to look at the entire length of the wire.
Good Luck
both switches
1 - 5 of 5 Posts
