1 - 20 of 26 Posts
OEM Moderator
Discussion Starter #1 (Edited)
Accelerator Pedal Assembly - See "Throttle Assembly"
APCM (Auxiliary Idle Controller)
(Ford) F5PZ-12B641-AA
(Ford) F5TF-12B641-AD with LCD display
APCM (Auxilliary Idle Controller) wiring harness
(Ford) XC3Z-14A411-AA
Air Dam
(Ford) F2TZ17626A
(Ford) F2TZ17626B
(Ford) F3TZ17626B (Fiberglass for Ford Lightning)
AC Delete Idler Pulley
(Ford) F5TE 19A216 AB F5TZ 8678 AC
(Motorcraft) YS-261
ACT Air Charge Temp Sensor
(Ford) F5AZ-12A697A (Plastic, in air filter housing)
(Ford) F3VY-12A647-A (Metal, in air filter housing)
Air Cleaner Housing Cover 94-97 F-series (Updated Cover)
(Ford) F6TZ-9661-AB
Air Cleaner Housing Nuts 94-97 F-series (Updated Spring Loaded Steel Nuts)
(Ford) F7TZ-9B680-AA
Air Filter, Open Element (Tymar, Etc)
(Baldwin) PA2818
(Donaldson) B085011
(Fleetguard) AH1141
Air Filter Gauge
(Ford) F7TZ-9N622-AA
Alternator
(Ford) F5UU-10300-CA (215Amp Ambulance alternator)
(Motorcraft) GL504RM 130A standard item (95)
(Motorcraft) GL500RM 110A (130A?) standard item (96-97)
Alternator Pully
(Ford) F5UZ-10344-C (8 rib mid 95 and newer)
Antifoaming Additive (counters RTV reaction with oil)
(Fleetrite) CH1824392
(Lubrizol) 888
Auto Hub Lock Grease
(Ford) E1TZ-19590-A
Auto Hub Nut Assembly
(Ford) F6TZ-3N105-BB (retainer nut, retainer key, 3 washers)
Battery Cable, Positive
(Interstate) 2114-001
Battery Cable, Negative, Passenger side
(Ford) F5TZ-14301-A
Bed Mount Insulators/Bushings 6 needed
(Ford) E9TZ-5C036-A
Belt - See Serpentine Belt
Block Heater w/o Cord
(Ford) F4TZ-6A051-A
Block Heater Cord
(Ford) F4TZ-6B018-B
Brake booster ZERO LOSS
(Ford) F5TZ-2005-CA
Brake dust shield '94 (may fit earlier years) left...... Ford
(Ford) F2TZ-2K005-A (left)
(Ford) F2TZ-2K004-A (right)
Brake Master Cylinder Sensor (at the end of MC)
(Ford) F3TZ-9F924-BB (original)
(Ford) 1L1Z-9G652-AA (replacement for recalled switches)
Brake Pads
(Bendix) MDK655FM (fleet grade)
(Ford) XU2Z-2V001-ASA (Autolite with hardware)
(Performance Friction) 0655.10 (96-97)
Brake Shoes
(Bendix) AF583 (semi-metallic)
Bumper, Front, Diesel, with Air hole, 92-97
(Ford) F3TZ-17757-AB
Bumper Strip, Front Center, Diesel, 92-97
(Ford) F3TZ-17K833-K
Bumper Strip, Front Outer Left, Diesel, 92-97
(Ford) F3TZ-17K833-J
Bumper Strip, Front Outer Right, Diesel, 92-97
(Ford) F3TZ-17K833-H
Bushings
(Energy Suspension) 4-7110 (radius arm; polyurethane 93-98 2WD F250-F350)
(Energy Suspension) 4-5106 (front sway arm; polyurethane)
(Energy Suspension) 4-5104 (rear sway arm; polyurethane)
(Energy Suspension) 4-4107 (Body mount bushings, 1980-1996)
(Energy Suspension) 4.3121 (2) (Axle Pivot Bushings, 90-96 2WD)
(Energy Suspension) 4.7115 (Track Arm Bushing 85-98 F350 4WD)
(Energy Suspension) See Page (Leaf Spring Bushings)
(Energy Suspension) 4.212G Front leaf spring bushing (black)
(Energy Suspension) 4.7115G Trac arm bushing (black)
(Energy Suspension) 4.5126G F350 Sway bar bushing (black)
(Energy Suspension) 4.2114G -Rear leaf spring bushing w/ common type bushing (metal outer sleeve).. (black)
Bushings, Radius Arm, Plastic insert spacer, not included with Energy Suspension Kits
(Ford) E5TZ-3B244-A (2wd, 2 needed)
Camshaft Bearings, up to 8/1995, maybe later.
(International) 1812317-C92
Camshaft Position Sensor (CPS)
(Ford) F6TZ-12K073-A 94-96 (old)
(Ford) F7TZ-12K073-A 97 (old)
(Ford) F4TZ-12K073-C 94-96 new revised one black in color
(Ford) F7TZ-12K073-B 97-03 new revised one
(International) 1821720C99 (below engine 375548)
(International) 1825899C93 (above engine 375548)
Camshaft Position Sensor (CPS) O-Ring
(Ford) F81Z-12B615-BA
(International) 1824948C1
Camshaft Position Sensor (CPS) shim kit
(International) 1826583C91
Catalytic Converter Delete Pipe
(Ford) F4TZ-5A212V
(Ford) XC2Z-5A212-AA (SD type, cheap but must be shortened)
Clutch
(LuK) 07-154TFW (replacement 12" used w/SMFW; incl. SMFW)
(LuK) 07-127 (12-1/4" clutch replacement)
Clutch Master Cylinder
(Ford) F2TZ-7A543-D (96-97)
Clutch Release Fork (Lever Assembly)
(Ford) E7TZ-7515-A
Clutch, Throwout Bearing
(BCA) FC65662
Coil Spring Shim, Height adjusting/leveling, F250 2wd
(Ford) 389117-S2 (service part, washer goes under coil spring)
Column parts - see steering and shift
Coolant Supplemental Additive
(Fleetguard) DCA5
(Ford) FW-15/FW-16
(Motorcraft) VC8
Coolant reservoir de-gas bottle
(Ford) F6TZ-8A080-EA (late OBS style)
(Ford) 2C3Z.8A080.AA (SD above radiator style)
Coolant Temp Sender
(Ford) F1SZ-10884-A (for gauge, mounts on water pump)
(Fordf) F4TZ-10884-B (for overheat light, RH front of block)
Coolant Test Strips
(Fleetguard) CC6202 (50)
(Fleetguard) CC2602A (four strips)
(Fleetguard) CC2602B (one strip)
Crankcase Breather (CCV) O-Rings
(Ford) F4TZ-6769-A (small; seals screw head; 1/pack)
(Ford) F4TZ-6769-C (large; seals breather adapter to valve cover; 2/pack)
(International) 1824452C2 (Small, 2 needed)
(International) 1820784C2 (large, 3 sided, 2 needed)
Dana 50 TTB Hub Lock Nut Tool
(OTC) 7158
Dana 50 TTB
(Ford) F6TZ-3N105-BB (spindle nut, washer, gasket, autohub bolt, retainer kit)
(Dana/Spicer) 708084 (spindle needle bearing and both seals)
(Dana/Spicer) 48816 (wheel bearing seal)
(Dana/Spicer) 660568 (spindle nut with pin)
(Dana/Spicer) 621028 (spindle lockwasher)
(Dana/Spicer) 621027 (spindle nut w/o lockwasher)
(Dana/Spicer) 706411X (inner wheel bearing and race)
(Dana/Spicer) 706074X (outer wheel bearing and race)
(Napa) BK1 (spindle bearing, inner & outer seal rebuild kit)
(Napa) 22311 (inner spindle)
(Napa) 711818 (outer spindle)
(Napa) 27452 (hub seals)
(Napa) B2110 (spindle bearings)
(Timken) 382A (wheel bearing; inner race)
(Timken) 387A (wheel bearing; inner bearing)
(Timken) SET38 (wheel bearing; outer bearing w/race)
(BCA) SET A-38 (Wheel Bearings)
(National) 415690 (wheel bearing seal)
(Chicago Rawhide) 27467 (wheel bearing seal)
Dana 60
(Ford) E0TZ-3C140-B (Spindle to knuckle bolt)
(Ford) B8TZ-4322-A (Spindle to knuckle nut)
(Dana/Spicer) 706047X (Carrier Bearing/Race)
(Dana/Spicer) 706046X (Inner Pinion Bearing/Race)
(Dana/Spicer) 706045X (Outer Pinion Bearing/Race)
(Dana/Spicer) 76659-1X (left axle assy)
(Dana/Spicer) 76659-2X (right axle assy)
(Dana/Spicer) 52148 (Inner axle seal) (updated)
(Dana/Spicer) 42449 (Pinion seal)
(Dana/Spicer) 700014 (Spindle bearing & seal kit)
(Dana/Spicer) 49803Outer axle stub (30 spline
Axle U-joints (greaseable)...3-0332...Neapco
(Ford) E5TA-3A094-AA (Trac bar frame bracke)
Inner spindle grease seal '92-'97...BRS-87...Motorcraft also F2TZ-1S175-CA...Ford
(Ford) F81A-5598.DB (4" Blocks)(on block)
-F250/350 Outer hub bearing/race '94-'97...A-38...BCA/Fed Mog
-F250/350 Inner hub bearing '94-'97...387A...BCA/Fed Mog
-F250/350 Inner hub race '94-'97...382A...BCA/Fed Mog
-F250/350 Inner hub seal '94-'97...415960...National/Fed Mog
Steering Components
(Moog/Fed/Mogal) ES3009R F350 (driver's side tie rod '94-'96)
(Moog/Fed/Mogal) ES3009R F350 (Pitman arm to tie rod '94-'96)
(Moog/Fed/Mogal) ES2012S F350 (Sleeve '94-'96)
(Moog/Fed/Mogal) DS1068 F350 (Pitman arm to passenger side tie rod '94-'96) (Moog/Fed/Mogal) DS1071 F350 (Steering arm to steering arm connecting tie rod '94-'95)
(Moog/Fed/Mogal) K80026 F350(Upper Ball joint '94-'97)
(Moog/Fed/Mogal) K8607T F350 (Lower Ball joint '94-'97)
(Moog/Fed/Mogal) K8958 F350 (0* Camber/Caster bushing '94-'99)
Double Cardan Front Drive shaft
-U-joint C.V. joint grease able
(Neapco) 2-4800HD...
(Spicer)5-213X
U-joint yoke side greaseable
(Neapco) 2-4900HD
(Spicer )5-231X
C.V. centering assy...R2-21-1179...
Dash Pad
(Ford) F2TZ-1504282-BAD (mocha/tan)
(Ford) F4TZ-1504282-AAY (light grey)
Dash repair kit for right (passenger's) side dash mount. Frequently get broken.
(Ford) F4TZ-1504366-A
Daytime Running Lights Module (Ford) F43Z-15A272-A (Check Ebay)
Door Latch
(Ford) F2TZ-1521813-A
Door Darts (Inside Panel Push Fasteners) (also available at almost any parts store)
(Ford) N802900-S
Door Inside Panel
(Ford) F4TZ-1523943-BAD (mocha/tan)
Door panel light (clear lense)
(Ford)F2TZ-13734-B (Driver's side )
Door Weatherstrip, Drivers side inside belt molding, Felt strip inside that window rubs against
(Ford) F2TZ-1521457-A
Dipstick
(Ford) F4TZ-6750-E (F-Series)
(Navistar) 1824405C1
(Econoline) F5UZ-6750-A
Dipstick Mount Seal Repair Kit with instructions
(International) 1846146c91 (silicone, loctite gasket eliminator, adapter gasket, dipstick o-ring)
Dipstick Tube O-Ring
(International) 875519C1
Engine Belt - See Serpentine Belt
Engine Cover, Front - See Timing Cover
Engine Top Cover
F81Z-6A949-AA (late 97 up medium size)
F81Z-6A955-AA (Plastic cast bracket for med size cover above)
YC3Z-6A949-AA (smaller 2000 up cover)
YC3Z-6A955-AA ( stamped sheet metal bracket for smaller cover above)
Engine Top Cover Nuts
(Ford) N800475S101
Engine Oil Temp Sensor (EOT) - See "Oil Temp Sensor"
Engine Oil Pressure Sensor (EOP) - See "Oil Pressure Sensor"
Engine, Shortblock
(International) 2504315c91 96-97
Exhaust Back Pressure Regulator (EPR solenoid; up to 98.5)
(Ford) F5TZ-6C673-A
Exhaust Back Pressure Regulator Valve EBPV
(Ford) (old F4TZ-9J460-A) (new 1C3Z-9J460-AA) (94-96; mounts on bracket above oil reservoir)
(International) 1825685C1 (early)
(International) 1825163C2 (late)
Exhaust Collector Donut - see turbo Exhaust Collector Donut
Exhaust Manifold to Head Bolts (flanged bolt with special prevailing torque threads)
(Ford) F4TZ-9S425-A
International 1820513C1
Exhaust Manifold Gasket
(NAPA) MS-16314
(Ford) F4TZ-9448-A
(International) 1814219C1
Fan Belt - see serpentine belt
Fender, Front, LH, 92-97
(Ford) F4TZ-16006-A
Fender, Front, RH, 92-97
(Ford) F2TZ-16005-A
Fender, Rear (bed side), LH, 6'34" Dual Fuel, 87-97
(Ford) E9TZ-9927841-F
Fender, Rear (bed side), LH, 6'34" Single Fuel, 87-97
(Ford) E9TZ-9927841-C
Fender, Rear (bed side), LH, 8' Dual Fuel, 87-97
(Ford) E9TZ-9927841-E
Fender, Rear (bed side), LH, 8' Single Fuel, 87-97
(Ford) F0TZ-9927841-A
Fender, Rear (bed side), RH, 6', 87-97
(Ford) E7TZ-9927840-D
Fender, Rear (bed side), RH, 8', 87-97
(Ford) E7TZ-9927840-C
Flexplate Crankcase spacer (94-99)
(Ford) F81Z-6A366-AA
Flexplate Engine Spacer (94-99)
(Ford) F4TZ-6A369-A
Flexplate Reinforcement Plate (94-99)
(Ford) F4TZ-6A366-A
Flywheel, Dual Mass
(Ford)F-7TZ-6477-DA
Friction Modifier, Limited-Slip Differential
(Ford)F3TZ-19B546-MA
Front Cover, Engine see - Timing Cover
Fuel Line, Low pressure supply and return
(Ford) F5TZ-9A318-C On the engine metal fuel line return (96 up)
(Ford) F5TZ-9C330-C On the engine metal fuel line supply (96 up)
Fuel Cap (Locking)
(Napa) 703-2614
Fuel Filter
(Fleetguard) FS1298
(Baldwin) PF7678
(International) 1822631C91
(Motorcraft) FD4595
(Racor) IN F4595
Fuel Filter Drain Cable (vans)
(Ford) F7UZ9J312 (cable assembly)
(Ford) F7UZ9728 (mounting bracket)
Fuel Filter Housing
(Ford) F4TZ-9155-B (engine serial no. 201680-before)
(Ford) F6TZ-9155-A (engine serial no. 201681-up to 98.5)
Fuel Filter Housing O-Rings, These -rings seal fuel drain valve, fuel heater, and fuel return fittings.
(Ford) F81Z-9C065-AA (early 99)
(International) 1831204C91 (early 99)
Fuel Filter Housing Reseal Kit (See "O-Rings" for Individual O-Ring sizes)
(Ford) F6TZ-9157-BA (96-97)
(Ford) F5TZ-9157-A (94-95)
Includes:
(Ford) F4TZ-9C064-A O-Ring Water in Fuel Probe
(Ford) F4TZ-9C065-A O-Ring Heater Connector
Fuel Filter Housing wiring
(Ford) F7TZ-9S277-AA
(International) 1807333C91 ???
Fuel Filter Lid
(International) 1825190C91
Fuel Filter Restricted sensor; on filter housing 94/95; on regulator block 96/97
(Ford) E8TZ-9S283-A
(International) 1809435C1
Fuel Filter Stand Pipe
(Ford) F5TZ-9236-A (94-97)
(International) 1825187C91
Fuel Filter Water Drain Valve (94-95) (96? 97?)
(Ford) F5TZ-9A153-A
Fuel Filter Water in Fuel Control Switch, not the part in the bowl
(Ford) F4TZ-9J294-A (94-97)
(International) 1821712C1 (In harness behind HPOP reservoir pass. side)
Fuel Filter Water in Fuel Sensor Probe, 94-97, the part in the bowl
(Ford) F5TZ-9J294-A
Fuel Filter Wrench
(MATCO) KD3526
Fuel Heater Element;
(Ford) F5TZ-9J294-A (94-97)
(International) 1825186C91 (94-97)
(Ford) F81Z-9J294-AA (98-02) Heavy duty, Can be made to fit 94-97, (International) 1831196C92 (98-02) Heavy duty, Can be made to fit 94-97,
Fuel Heater Thermostat
(Ford) F4TZ-9J294-A
(International) 1823587C91
Kit Fuel Hose,
(Ford) F4TZ-9324-CA, 3" Long lift pump to filter inlet
(Ford) F4TZ-9324-DA Shorter than above, Filter outlet to High Pressure (piston) pump inlet
also can use blue push lock hose (Aeroquip FC498-06)
Fuel Line Banjo Outlet Seals (seals banjo fitting of "wishbone" line)
(Ford) F4TZ-9A375-A
Fuel Line Damper (96/97 CA; mounts on lift pump banjo fitting)
(Ford)F6TZ-9N163-AA
Fuel Line Damper Gasket (copper washer; not included w/damper)
(Ford) F6TZ-9160-AA
Fuel Line Seals (seals lines at head inlet fittings)
(Ford) F4TZ-9C387-A (94-97)
Fuel Pressure Regulator Repair Kit (contains spring, valve spool & new brass plug)
(Ford) F5TZ-9K061-A (federal emissions; 94-98)
(Ford) F6TZ-9K061-AA (CA emissions; engine serial no. 201681-98)
Fuel Pressure Regulator Spring
(International) 1823643-C1 (federal emissions; 94-98
(International) 1825854-C1 (CA emissions; engine serial no. 201681-98
Fuel Pressure Regulator Screen Kit (Orifice Vent Kit) Includes screened plug, o-ring, check valve
(Ford) F6TZ-9150-AA Screen and o-ring kit
(Ford) F5TZ-9A214-A ??? KIT-VENT ASY -DUAL
Fuel Pump
(International) 1824415-C93
(Ford) F6TZ-9350-A
Fuel Pump, Banjo Fitting
(International) 1821624-C92
Fuel Pump Banjo Gaskets
(Ford) F4TZ-9A375-A
(International) 1820650C1
Fuel Rail Plug O-Rings (the small 1/4" square drive drain at ends of heads )
(International) 182261891 (1815734C1 ?)
Fuel Rail Plug
(International) 1822618C92
Fuel Tank Pickup Umbrella
(Ford) E5TZ-9J306-BA
Fuel Tank Float
C0ASZ-9202-B
Gasket Set
(International) ???? 1830826c93 96-97 Head gasket and valve seal set
Glow Plugs
(Motorcraft) ZD-10 or ZD-11 (Beru plugs)
(Ford) F4TZ-12A342-A
(International) 1820697C2
Glow Plug Deactivation Kit (opens at 115 degrees coolant temp)
(International) 1831142C91
Glow Plug Relay
(Allied Electronics) 576-1078 (Stancor Heavy Duty 586-902)
(AutoZone) MR99
(Ford) F7TZ-12B533-CA (94-96 with pigtail)
(Ford) F81Z-12B533-AC (96-early 2000 w/o pigtail)
(International) 1807230C2
(International) 1826634C94
(Napa) GPR-109
Glow Plug Relay Cover
(Ford) F6TZ-12A345-A
Glow Plug Relay shunt; Required for GP monitor circuit; 97 CA
(Ford) F7TZ-12B533-B
Grill l-Black, 92-97
(Ford) F4TZ-8200-H
Grill - Chrome/Patinum, 92-97
(Ford) F4TZ-8200-A
F4TZ-8200-ACP (same grill but discounted truckload parts program)
Grill - Grey, 92-97
(Ford) F6TZ-8200-AAA
Grill Emblem
(Ford) F87Z-9842528-CA
Headlight Assembly; 92-97
(Ford) F2TZ-13008-A (RH)
(Ford) F2TZ-13008-B (LH)
Headlight Switch
(Ford) E7TZ-11654-B (or SW-2103) Switch Assembly
OEM Moderator
Discussion Starter #2 (Edited)
High Pressure Line (hydraulic clutch)
(Ford) F5TZ-7A512-A
High Pressure oil rail o-rings For rail plugs, elbows and ICP
(Ford) F4TZ-9N693-A
(International) 1815874C1
High Pressure Oil Pump (Includes F81Z-AA IPR valve; uses F4TZ-A gasket)
(Ford) F4TZ-9A543-BRM (engine serial no. up to 201680)
(Ford) F6TZ-9A543-ARM (engine serial no. 201681 through 99)
(Ford) F81Z-9A543-CA (99.5)
(Ford) F81Z-9A543-BRM (98.5/99)
(Ford) F81Z-9A543-CRM (99.5 up 17 deg pump) IH 2589446c91
High Pressure Oil Pump Fitting O-Rings
(International) 1823790C1
High Pressure Oil Pump Gasket
(Ford) F4TZ-9417-A (engine serial no. 201680 & before)
(Ford) F6TZ-9417-AA (engine serial no. 201681 & up
High Pressure Oil Pump Gear Bolt cover
(Ford) F4TZ.6B070.A
High Pressure Oil Rail end plugs Large plugs at each end of heads; incl. o-rings
(International) 1827535C94 (new style, blue o-ring)
(Ford) 4C3Z-6026-CA (new style)
High Pressure Oil Reservoir
(Ford) F4TZ-6658-A (engine serial no. 201680 & before)
(Ford) F6TZ-6658-AA (engine serial no. 201681 up to 98.5)
High Pressure Reservoir Gasket
(Ford) F4TZ-6619-A -Engine number 201680 & below; partial gasket RTV required
(Ford) F6TZ-6619-AA -Engine number 201680 up to 98.5; full gasket, no RTV
International) 1818357C1 94-95.5 type partial gasket RTV required
(International) 1823670C1 95.5-97 with standpipe
(Ford) YC3Z-6619-BA Last version w/ metal screen (do not used on older applications)
High Pressure Oil Supply Hoses
97 and before
(Ford) F6TZ-9A332-A (left)
(Ford) F6TZ-9J323-A (right)
98 and up
(Ford) F81Z-9A332-AA (left)
(Ford) F81Z-9J323-AA (right)
High Pressure Oil Supply Fittings
(Ford) F4TZ-9N332-A (elbows on cylinder head oil rails)
(Ford) F4TZ-9C402-A (HP oil pump fitting and o-ring)
High Pressure Quick-connect fitting on cylinder head oil rails; 98 up
(Ford) F81Z-9N332-AA
Hood, 92-97
(Ford) F2TZ-16612-A
Hood Hinge, LH, 92-97
(Ford) F2TZ-16797-A
Hood Hinge, RH, 92-97
(Ford) F2TZ-16796-A
Hood Spring, LH, 92-97
(Ford) F2TZ-16826-B
(Ford) F2TZ-16826-A
Horn Pad - see Steering Wheel
Hub Nut Removal Tool
(OTC) 7158 (94)
(OTC) 7157 (later)
OEM Moderator
Discussion Starter #3 (Edited)
ICP Connector
(International) 2501105c1 (also EBPV Connector)
ICP Sensor
(Ford) F4TZ-9F838-A (94/95)
(Ford) F6TZ-9F838-A (96-up; marked Julian date 6318 or higher)
(International) (94/95) 1830669C92 $128
(International) (96-up) 1807329C92
ICP O-ring (Same as HP plugs and hoses)
Idler Pulley - see Serpentine belt Idler
Ignition Cylinder Lockset with Key; Black fingerhold
Measure the old key at the 6th (10 total) cut back from the front, to find the cut # to order
With the same cut number, cut last 4 positions from old key to new, and it will work in the doors too
(Ford) F3DZ-11582-A, (Number 1 cut A, approx 0.35")
(Ford) F3DZ-11582-B, (Number 2 cut B, approx 0.30")
(Ford) F3DZ-11582-C, (Number 3 cut C, approx 0.25")
(Ford) F3DZ-11582-D, (Number 4 cut D, approx 0.20")
(Ford) F3DZ-11582-E, (Number 5 cut E, approx 0.15")
IVS (Idle Validation Sensor) 94-97 - See "Throttle Idle Validation Sensor"
IPR Connector with 12" Pigtail
(International) 2501107C1
IPR O-Ring Kit (for when IPR valve replacement is not required)
(Ford) F6TZ-9C977-AN (F6TZ-9C977-AA?)
(International) 1825806C92 (1825806C91?)
IPR Injection Pressure Regulator
(Ford) F4TZ-9C968-C (engine serial no. 187099 & before or pump no. 255C92)
Part number F4TZ9C968C was superceded by part number 2C3Z9C968BA
(Ford) F81Z-9C968-AA (engine serial no. 187100 & up or pump no. 247C91)
(International) 1824982C91 (engine serial no. 187099 & before or pump no. 255C92)
(International) 1833798C91 (All Years ???) latest part number
(Motorcraft) CM-5013
Injectors
(Ford) F81Z-9E527-DRM (federal emissions & SuperDuty)
(Ford) F81Z-9E527-ARM (California emissions)
(Ford) F81Z-9E527-BRM (99.5 only)
Injector O-ring kits (replaces all previous kits, 8 needed)
(Ford) XC3Z-9229-AA or XC3Z-9229-AB
(International) 1833564C91
Injector Oil Deflector / Spout
(Ford)F4TZ-9G524-A
Injector Removal Tool
(OTC tools) 6067
Injector Driver Module (IDM)
(Ford) F7TZ-12B599-AC (F-Series)
(Ford) F6TZ-12B599-AA (Econoline)
(Ford) F6UZ-13C795-AA & -BA (seals for Econoline)
(Ford) XC3Z-12B599-AA (98-03)
Injector Sleeves
(Ford) F4TZ-9F538-A (94-03 7.3L)
IDM seals for E-van
Intake Hose Kit (updated kit replaces orange hose, includes replacement for aluminum center section)
(Ford) F7TZ-9C681-AA
Intake Hose, updated black (Replacement hose for above, does not directly replace orange hose)
(Ford) F81Z-9C681-BA
Intake Plenum
(Ford) F81Z-9E434-DA or F81Z-9E434-D4 (96-03 newer type with screen, 10 bolt and 3")
(IH) 1828036C1 (96-03 newer type with screen, 10 bolt and 3")
Lift Pump - see fuel pump
Light assembly, Underhood
(Ford) 1U5Z-15702-AA
MAP Sensor
(Ford) F4TZ-9F479-A (94-98; digital)
Neutral Safety Switch (hydraulic clutch)
(Ford) FF57Z11A152A (96-97)
O-Rings, Standard sizes for replacements
Fuel System O-Rings (use Viton for fuel)
#123, 94-95 FPR Bowl
#025, 96-97 FPR Bottom plug, outer (seals plug to housing)
#110, 96-97 FPR Bottom plug, inner (seals fuel return to HP side of pump)
#012, 94-97 Water In Fuel Sensor Probe
#014, 94-97 FPR
#015, 94-97 FPR to Filter Housing
#011, 94-97 FPR Screen Plug, Smaller o-ring
#012, 94-97 FPR Screen Plug, Bigger o-ring
#018, 94-97 Fuel Heater Connector
#202, 94-97 Water Drain (2 required)
#???, Fuel rail end plugs in head
Oil O-rings (use Buna-N for oil (Nitrile)) (70 durometer is standard, use 90 durometer for the HP Oil fittings)
#013, Oil Rail Plugs, ICP, and HP hose Fittings (90 durometer)
#012, Dipstick tube to Bung (70 durometer)
#216, Oil Rail Galley Plugs ???
#010, CCV, small o-rings (70 durometer) (2 required)
#???, CCV, large o-rings (70 durometer) These are currently 3 sided, get from International (2 required)
#140, HPOP Rear cover
#???, Turbo pedestal o-ring, large
#???, Turbo pedestal o-ring, small
#117, CPS o-ring (70 durometer)
#???, Oil Cooler o-ring, inner
#???, Oil Cooler o-ring, outer
#140, Turbo to Y-Pipe (140 fits, stock is a Quad ring)
#???, E4OD Dipstick tube o-ring
Coolant O-Rings
#???, Thermostat Housing
#???, Lower Inlet Pipe (later Pump)
#???, Hose fitting (later Pump)
O-Rings, Individual OEM
Fuel Rail End Plug O-Rings (the small 1/4" square drive drain at ends of heads )
(International) 1815734C1
(Ford) F4TZ-9N693-A
Oil Cooler O-Rings (2 each needed)
(Ford) E3TZ-6C610-A
(Ford) E4TZ-6K649-E
(International) 1807563-C1, Inner
(International) 1804414-C1 Outer
Thermostat Gasket (o-ring)
(Ford) F4TZ-8255-A
(Intl) 1821880C2
Turbo Compressor Outlet to Y-Pipe O-Ring
(Ford) F4TZ-9E436-A (94-99)
(International) 1818372C1
Turbo Pedestal O-Rings (between pedestal & block; pedestal & turbo)
(Ford) F4TZ-6N653-A & -B
(International) 1815560C1 Turbo to pedestal O-ring .421 x .560
(International) 1815561C1 Turbo to pedestal O-ring .769 x .908
Water Pump Inlet Pipe Gasket (o-ring)
(Ford) F81Z-8255-AA
Oil, Anti-Foaming Additive
(International) CH1824392
Oil Cooler Housing, filter end 94-97; Updated snap ring retained check valve
(Ford)F81Z-6881-BA
Oil Cooler housing, Front, 94-97
(Ford) F4TZ-6881-B
Oil Cooler Housing Gasket (front)
(Ford) F7TZ-6A636-AAA ???
(International) 1831666C1
Oil Cooler Housing Gasket (rear; oil filter end)
(Ford) F4TZ-6A636-AA (97-up)
(Ford) F4TZ-6A636-B (96-before)
(International) 1831665C1
Oil Cooler O-Rings (one each to seal cooler at each header)
(Ford) 1C3Z-6C610-BA
(Ford) 1C3Z-6K649-BA
Oil Cooler Tube / Core
(Ford) 1C3Z-6A642-AA
Oil Filter
(Fleetguard) FL3630 - 11.51
(International) 181456261 - 11.51
(Motorcraft) FL1995
(NAPA) 1734
Oil Filter Housing 94-97 (updated snap ring retained check valve)
(Ford) F81Z-6881-BA
Oil Fill Extension (6" Super Duty style, uses same cap)
(Ford) 4C4Z-6783-AA
Oil Fill Cap
(Gates) 31109
Oil Gallery Drain plugs, under valve cover, aluminum
(International) 1822610C91
Oil Pan Drain Copper Gasket
(Ford) F4TZ-6734-B
Oil Pressure Sender Switch
(Ford) E9SZ-9278-A (engine serial no. 201680 & before)
(Ford) F6TZ-9278-AA (engine serial no. 201681 up to 98.5)
Oil Pump Gear Set
(Ford) XC3Z-6608-AA
Oil Pump Gasket
(Ford) XC3Z-6619-AA
Oil Pump Housing (front seal housing)
(Ford) F4TZ-6616-A
Oil Pump Pickup Tube Gasket
(International) 1915899C3
Oil Rail End Plugs (large plugs at each end of heads; incl. O-rings) -
see "High Pressure oil Rail"
Oil Temp Sensor (EOT) , Engine
(Ford) F2AZ-12A648-A (not sure early or late)
(International) 1814320C1 (engine serial # 375548 and below)
(International) 1824451C1 (engine serial # 375549 and up)
Oil Temp Sensor (EOT) Connector, Engine
(International) 2501106C1 (dealer must get these in 10 packs. May or may not order if you only want one...)
(Ford) E1AZ-12A648-A (not available?)
(Terminal Supply Co) FPT-91-6995
Parking Brake Cables, Crew Cab LWB
(Ford) F6TZ-2A635-C (Driver’s Side)
(Ford) F6TZ-2A635-CC (Passenger Side)
(Ford) F2TZ-2A793-A (Intermediate Cable)
Parking/Signal Light, LH, 92-97
(Ford) F5TZ-13201-AB
(Ford) F5TZ-13200-AB
Piston, Pin & Rings
(Ford) F4TZ-6102-A (engine serial no. 201680 & before)
(Ford) F5TZ-6102-A (engine serial no. 201681 up to 98.5)
Power Steering Hose
(Ford) F4TZ-3A719-D (High Pressure)
(Gates) 360880 (96 Pressure)
(Gates) 370660 (96 Return)
Power steering pump kits
(Gates) 350450 (rebuild kit)
(Gates) 351210 (seal kit)
(Gates) 348740 (driveshaft seal kit)
Power steering gear kits
(Gates) 350520 (complete rebuild kit)
(Gates) 351240 (major seal kit)
(Gates) 350900 (input shaft seal kit)
(Gates) 351260 (Complete Pitman shaft seal kit)
(Gates) 49070 (Lower Pitman shaft seal kit)
Push Rods (valve train)
(Ford) F4TZ-6565-A
RABS Rear Antilock Brake System control vave assembly
(Ford remanufactured) XL3Z-2B373-AARM
Radiator
(Modine) 1R 2554 (mid 95-97 with cap in separate degas bottle)
Radiator Cap
(Gates) 31406 (late)
Radiator Hose Newer style early 95-98, with coolant bottle
(Ford) F5TZ-8260-E (upper)
(Gates) 22158
(Ford) F5TZ-8286-G (lower)
(Gates) 22216
(Ford) F4TZ-8075-B (from lower hose T to coolant bottle)
(Gates) 22217
Radiator Core Support , all F250-F350 Diesels, 92-97
(Ford) F4TZ-16138-A
Radiator Petcock,
(NAPA) P/N BK 6051366 (for 2000 but should fit other years)
Relay Shunt (required for glow plug monitor circuit; 97 CA emissions)
(Ford) F81Z-12B533-BA
Restricted Fuel Filter Sensor - see fuel filter restricted sensor
Rocker Arm
(International) 1814259-C91
RTV Silicone Sealer (special sealant for powerstroke)
(Ford) F5TZ-19G204-AB (5oz caulk tube for oil pan etc)
(Motorcraft) TA-31 (5oz caulk tube for oil pan etc)
(Ford) F7AZ-191554-EA (5oz, 1/2 caulk tube for intake plenums)
(Motorcraft TA-30 (5oz, 1/2 caulk tube for intake plenums)
(Wacker) T-442
(Internatioal) 1830858C1
Seat Belt Extension
(Ford) E3FZ-61611C22-B Extension I got from Ford Dealer, about 10"
(Ford) FO3Z-5461248-A Belt adjustment clip for child seat
Seat Foam, Lower Captains Chair
(Ford) F2TZ-18632A22-
Seat Foam, Lower 40/20/40
(Ford) F4TZ-15632A22-A
OEM Moderator
Discussion Starter #4 (Edited)
Serpentine Belt
(Ford) F6TZ-8620-GA (1995-up 8 rib)
(Ford) F5TZ-8620-A (1994.5 7 rib)
(Napa) 25-081189 (1995-up 8 rib)
(Unknown) JK7-1201 (1994.5 7 rib)
(Goodyear Gatorback) 4071195 (1994.5 7 rib)
(Gates) K01189 (8 rib late)
Serpentine Belt Tensioner (single) 94-97
(Ford) F7TZ-6B209-AA
(AutoZone) 199236
(Gates) 38119 (revised design)
Serpentine Belt Idler Pulley (Upper, no grooves)
(Ford) F6TZ-8678-GB
(Motorcraft) YS-267
(Napa) 38052
(Autozone) 231057
Serpentine Idler Pulley (7-rib 94 only)
(Ford) F5TZ-8678-A
Serpentine Belt Idler Pulley (Lower Grooved, 8 rib)
(Ford) F6TZ-8678-HB
(Motorcraft) YS-268
(Autozone) 231048
Serpentine Belt Pulley Bolt, RH Thread T50
(Napa) 56040
Serpentine Belt Dual Tensioner Upgrade MOD
(Ford) F8UZ-6B209-CA Dual Tensioner (E series)
(Ford) F8TZ-8620-FB Belt (F-Series)
(Ford) F8UZ-8620-BA Belt (E-Series)
(Ford) F8UZ-8B656-AB Decal to replace old
SD Pickup tensioner F8TZ-6B209-BA (easier to change belts per MASAMI)
Belt, Motorcraft JK8-1227, 122-7/8" long
Belt, Ford 1CZ-8620-LA
Shift Lever Rebuild Parts, Automatic (See Pic)
(Ford) F4TZ-7210-B Shift Lever Assembly (item 2)
(Ford) 1F1Z-7212-AA Transmission Tube $17.09
(Ford) F3TZ-7L278-A Bushings (need 2) $1.76ea
(Ford) F7DZ-7R264-AA Plunger $10.60
(Ford) F2UZ-7A214-CA Shift Lever Cap
Side Marker Light, Front, LH, 92-97
(Ford) F2TZ-15A201-D
Side Marker Light, Front, RH, 92-97
(Ford) F2TZ-15A201-C
Slave Cylinder
(Ford) E3TZ-7A564-A (96-97)
Sonnax Valve
(AX4N) 96948-01K - .427" dia
(Early E4OD) 36948-05K - .375" dia
(Late E4OD) 36948-03K - .331" dia
Starter
Starter Solenoid (mounted on starter motor - can be serviced separately)
(Ford) F4TZ-11390-A (F4TZ-9N332-A ???)
Steering Column Shifter parts - see shifter
Steering Wheel
(Ford) F6TZ-3600-AA (MAY BE A BAD NUMBER)
Steering Wheel pad, with Horn and Cruise 92-97
(Ford) F2TZ-13A805-F
Steering Column Upper Bearing Kit
(Ford) F6AZ-3605-AA (contains steel tolerance ring, steel sleeve, bearing pre-load spring, upper bearing snap
ring, steering wheel attaching bolt, small upper bearing, large upper bearing, & instruction sheet)
(Ford) FODZ-3L539-F (as above but no bearings)
Tail Light, LH, 92-97
(Ford) F2TZ-13405-A
Tail Light, RH, 92-97
(Ford) F2TZ-13404-A
Tailgate, all F-Series 87-97
(Ford) E7TZ-9940700-A
Tailgate Cover, Inner, 87-97
Temp sending unit - see "engine oil" or "coolant"
Thermostat
(Ford) F4TZ-8575-A (engine serial no. 201680 & before)
(Ford) F6TZ-8575-AA (engine serial no. 201681 up to 98.5) (Old style with separate O-ring) (obsolete part number)
(Ford) F6TZ-8575-BA ) or ( Motorcraft) RT1197 (new style with integral O-ring)
(Gates) 33909 (late)
(Ford) F4TZ-8255-A or (Motorcraft) RG581
(Intl) 1821880C2
(Gates) 33607
Thermostat Housing
(Ford) F4TZ-8592-AA (Motorcraft) RH 110
Throttle Assembly (Includes Pedal, TPS, & IVS) 94-97
(Ford) F5TZ-9F836-A (f-Series) 94-95
(Ford) F6TZ-9F836-AA (F-Series) 96-97
(Ford) F5UZ-9F836-B (Econoline)
Timing Cover; Front
(Ford) F4TZ-6016-A (engine serial number 201680 & before)
(Ford) F6TZ-6019-AA (or CA) (engine serial number 201681 thru 96)
(Ford) F7TZ-6019-AA (97-up)
(International) 1820509C91 Early
(International) 1824537C91 Late
Timing Cover Aeration Valve (air bleed by oil pump)
(International) 1823633C1
Timing cover seal kit; comes with all 3 of the different HPO reservoir gaskets, timing cover gaskets, water pump gasket, oil pickup tube gaskets ,tube of RTV,3 hole HPOP gasket
(Ford) YC3Z-6020-BA
Timing Cover Crankshaft Seal Kit with wear ring
(International) 1812376c92
(National) 3894VD (seal only)
Transfer case range indicator switch
(Ford) 3L5Z-7E440-AB (97 and ???)
Transfer Case Output Seals (4407)
F4TZ-7B215-A Shaft Seal
E7TZ-7052-A Spline seal (goes under yoke nut)
Transmission coolers
(Ford) 5C3Z-7A095-CA (6.0 26 rows)
(Ford) 5C3Z7A095-B (6.0 31 rows)
(Ford) 3C3Z-7A095-AA (V10)
(TruCool) 4739 (V-10 sized cooler but w/ npt fittings, will fit in bumper 94-97)
Transmission cooler line check valve
(Ford) FOTZ-7D174-A, inline upgrade for models w/o
(Ford) FOTZ-7D174-B, with 5/16 line
(Ford) FOTZ-7D174-C, with 3/8 line
Transmission Dipstick; 4R100 Style, 12" longer but Tube needs Serious tweaking/bending to fit 94-97
(Ford) F81Z-7A020-BA (Dipstick)
(Ford) XC3Z-7A228-AA(Tube)
Transmission Filter
(Ford) F6TZ-7A098-BB (with seal)
Transmission Gasket
(Ford) F6TZ-7A191-A (reusable)
(Ford) E9TZ-7A191-A
Transmission solenoid pack harness (exterior) F5TZ-7C078-A
Transmission Pan with Drain (4R100 pan, fits E4OD & uses same filter; must use reusable gasket above)
(Ford) F81Z-7A194-BA (4wd, deep)
(Ford) F81Z-7A194-AA (2wd, shallow)
Turbo Charger Assembly (remanufactured)
(Ford) F6TZ-6K682-ARM (up to 98.5; turbine & compressor)
(Ford) F4TZ-6K682-BRM (up to 98.5; complete-incl pedestal & EPR)
(Ford) F8UZ-6K682-AARM (98.5/99 Econoline w/o EBP)
(Ford) F81Z-6K682-AARM (99 F-series w/o EBP)
(Ford) F81Z-6K682-AA (99 F-series w/EBP)
(Ford) XC2Z-6K682-AARM (99.5 Econoline w/o EBP)
(Ford) F81Z-6K682-CARM (99.5 F-series w/o EBP)
(Ford) F81Z-6K682-BARM (99.5 F-series w/EBP)
Standard O-Ring, #140 will fit
Turbo, Compressor Wheel
(Schwitzer?) 170293 C/W
Turbo Exhaust Collector (up-pipe) Donut (at top of each manifold-to-turbo pipe)
(Ford) F4TZ-6K854-C
(Napa) F17250. Up-pipe donuts for Small Block Chevy V8
(International) 1816103C1
Turbo Exhaust Inlet Gasket (between turbo inlet & collector)
(Ford) F4TZ-6N640-B
Turbo Pedestal
(Ford) F4TZ-6N639-AARM (up to 98.5)
(Ford) F81Z6N639-BARM (99 F-series w/o EBP)
(Ford) F81Z-6N639-AARM (99 F-series w/EBP)
(Ford) F81Z-6N639-DARM (99.5 F-series w/o EBP)
(Ford) F81Z-6N-639-CARM (99.5 F-series w/EBP)
(International) 1822873C1 (Non EBPV pedestal)
(International) 1815560C1 & 1815561C1
Turbo Seals and Bearings, Kit
(World Products) 7-A-2058
Turbo Reman Rotating Assembly, TP38
(International) 991825C92
Turbo Y-Pipe hoses (Y-pipe to heads, 2 used)
(Ford) F6TZ-6C640-A
Turbo Bellows Up-pipe
1843486c92 OBS>>
1837872c93 99.5-03
Up Pipe - see Turbo Exhaust Collector
Vacuum Low Switch (sending unit activates brake warning light)
(Ford) E3TZ-12A182-H
Vacuum Pump
(Ford) F4TZ-2A451-A (94-95)
(Ford) F6TZ-2A451-AA (96-97)
Vacuum Pump Pulley
(Ford) F5TZ-2L487-A (94-95) ???
(Ford) F5TE-2L487-AA (96-97) ???
Valve Cover Harness Repair Kits (contains 4 hard shells w/seals, w/o terminals)
(Ford) F7TZ-14489-BA (94-96)
(Ford) F7TZ-14489-AA (97)
(International) 1830829C91 removal tool and Shells w/o pins
(International) 1661875C1 Pins
(International) 2501055C1 Pins with 6" wire
Valve Cover Pigtails with plug and wires, OBS
(Performance Specialties) 99288
Valve Cover Gasket (94-97)
(Ford) F4TZ-6584-A
(International) 1818350C2
Valve Cover Harness, under valve cover
(Ford) F4TZ-9D930-K (94-97)
(International) 1815923C92 (94-97)
VSS Vehicle Speed Sensor
(Ford) F85Z-2L373-AB (or -AC) (97 and ???)
Up-Pipe Donut - see turbo Exhaust Collector Donut
Vent Register
(Ford) F3TZ-19893-H
Water in Fuel Sensor- See Fuel Filter Water in Fuel Sensor
Water Pump
(Ford) F81Z-8501-BRM (engine serial no. 201680 & before)
(Ford) F81Z-8501-CRM (engine serial no. 201681 up to 98.5)
Water Pump O-Ring Seal / Gasket
(Ford) F4TZ-8507-A
(Ford) F8TZ-8255-AB
Water Pump Inlet Tube, 97-98
(Ford) F81Z-8592-BA
Water Pump Pulley 95-97
(Ford) F7TZ 8509-AA
Wing Window Handle Kit
(Ford) E9TZ-1522916A (RH)
(Ford) E9TZ-1522917A (LH)
Wheel Opening Moulding, Front L, Chrome, 87-97
(Ford) ???
Wheel Opening Moulding, Front R, Chrome, 87-97
(Ford) E7TZ-16038-A
Wheel Opening Moulding, Rear L, Chrome, 87-97
(Ford) E7TZ-9829165-A
Wheel Opening Moulding, Rear R, Chrome, 87-97
(Ford) E7TZ-9829164-A
OEM Moderator
This is a work in progress from a variety of sources. Please feel free to add on in the form of posts and I will try and keep this up to date and include new stuff. This will only be as good as the contributions to it.
Tom
OEM Moderator
OK guys I got this started how about some helping building this and getting the numbers updated.
Senior Member
This is great Tom!
I have a parts number interchanger it is a humongous pdf file but I am not sure how to post it cause it is 97 pages long! It has IH to Ford part number interchange with a search engine. cool file! :D
Here Tom is another part number for the blue cps if anyone wants it just came across it....blue CPS - 1807339C92 International
Powerstroked
Tom,
The part number for the Energy suspension front leaf bushings is incorrect
The part number is actually "4.2121G", I couldn't find the 4.212G on Summit's site and finally browsed only to find that you were missing a "1"
Im needing to find out the part number for the ruber o rings/gaskets for the crankcase breather, i think thats what its called, it sits on top of the drivers side valve cover and its a small box looking thing that leads into the intake pipe. I need them ASAP! Thanks!!!
In edit here you go:
I dont know about the later number but the early part # for the HPOP gasket is the wrong part number.
I ordered it and from what I understand its for an inline 6 cyl.
1815898C3 This IH # will cross with Ford # F4TZ-9417-A
Rob
1 - 20 of 26 Posts
