1 - 1 of 1 Posts
Hey everyone. I have some parts that are just sitting around my warehouse. Looking to get them gone at a discount. There are parts for Cummins and Duramax's in there so don't get scared. Tell your friends! Quantity on most of these is only 1 or 2, aside from the AFE Stock replacement 7.3 air filters and oil filters. I have TONS of those. Shoot us a message or call if you have any questions.
888-99-DIESEL
CAM-110111 Camburg Performance Dual Shock Lower Arm Kit 2010-2013 Ford Raptor SVT
CAM-110098 Camburg Performance Lower Arm Kit 2010-2013 Ford Raptor SVT
JKS-2210 JKS ACOS Front Adjustable Coil Spacer Lift Kit 2007-2015 Jeep JK
AFE-51-12322 AFE Magnum Force Stage 2 Cold Air Intake System 2013 6.6L GM LML-Pro Dry S
AFE-51-41262 AFE MAGNUM Force Stage 2 Intake 08-10 6.4L Ford PowerStroke-Pro Dry S
AFE-20-91061 AFE Universal Air Intake Filter 9x7x9
AFE-21-91046 aFe Power MagnumFLOW IAF PRO DRY S Air Filters; 6 F x 9 B x 9T (Inv 4-3/4) x 7-1/2 H in
AFE-75-73005 AFE Momentum HD Pro-Guard 7 Stage 2 Si Cold Air Intake 11-13 6.7L Ford Powerstroke
AFE-50-74004 AFE Momentum HD Pro 10R Stage 2 Si Cold Air Intake 07.5-10 LMM GM Duramax
AFE-51-80392 AFE Stage 2 Intake Type Si 03-07 6.0L Ford PowerStroke 54/51/75-80392 (Pro Dry S)
AFE-30-10005 AFE Stock Replacement Filter Early 99 7.3L Ford Powerstroke 30/31/73-10005 (Standard 5 Layer)
AFE-44-LF004 AFE Pro-Guard D2 Replacement oil filter for 1994-2003 7.3L Ford Powerstroke
DE-221001 Diamond Eye 4 Aluminized Down Pipe 1994-02 5.9L Cummins""
FLO-664 FLO~PRO 2011-13 GM Duramax Downpipe Back DPF Delete 5" Single Exhaust Kit No Bungs-Aluminized WITH Muffler
DE-K4330A Diamond Eye 4" Cat Back Exhaust 11-13 Ford F150 EcoBoost-Aluminized
ATI-917376 ATI Super Damper Harmonic Balancer 2011+ LML GM Duramax
ATI-918999D Installation Kit for the above item ATI-917376
FOX-980-24-986 Fox 2.0 Performance Series IFP Steering Stabilizer 07-13 Jeep JK
FOX-985-24-001 Fox 2.0 Performance Series Steering Stabilizer 08-13 Ford SuperDuty
ICON-51200 ICON Vehicle Dynamics 2007-11+ Tundra Rear Leaf Spring Expansion Pack 51200
ICON-58630 ICON Standard Travel Front Coil-over Shock Kit 4Runner/Tacoma 58630
ICON-61-1031 ICON Vehicle Dynamics Billet Sway Bar Relocation Brackets 10+ FJ Cruiser
ICON-64050 ICON 2008-11+ Ford Super Duty 4WD 4.5 Lift Box Kit 64050
CROWN-DODGE12FR07+Black+8 Crown Brake Lines Dodge Ram 2500 4WD 2003-2011 0"-12" Lift-7-9" Lift
CROWN-DODGE12FR07+Smoke+8 Crown Brake Lines Dodge Ram 2500 4WD 2003-2008 0""-12"" Lift (7-9"" Lift)"""
SBJE1012S Sprint Booster 07-12 Jeep JK Automatic Trans
PPE-513020000 PPE Fuel Rail Pressure Gauge Cummins/Duramax-06-12 Duramax
BW-6758-179388 BorgWarner EFR 6758 Turbocharger (.64 A/R T25 Single Scroll WG)
BW-179258 BorgWarner 8374 T3 Flange
BD-1401579P BD Metal Drives Side Intercooler Pipe 03-07 6.0L Powerstroke
HS-HS54579 Victor Reinz Black Diamond Complete Head Gasket Set 2003-2007 6.0L Ford Powerstroke-20mm Dowel
DP-DP3-4BT Diesel Pros DP-3 Performance Cam 4BT 3.9L Cummins
DP-DP3 Diesel Pros DP-3 Performance Cam 94-07 5.9L Cummins
DP-DP4 Diesel Pros DP-4 Performance Cam 94-07 5.9L Cummins
DP-KillerBRegrind Diesel Pros Killer B Performance Cam 94-12 5.9/6.7L-Regrind
TCS-618102 TCS Extreme Duty Billet Output Shaft 96-07 5.9L Cummins 47RE / 48RE
1 - 1 of 1 Posts
