1 - 20 of 30 Posts
Motors are complete except turbos and injectors. All were pulled from non-running trucks that Im doing Cummins conversions.
2003- good compression (320-340) across all cylinders
2005- low compression 240- 280
2006- low compression 200 across all cylinders
2006- unknown compression. Has a remanned engine tag on it
I have the ficms, 3 turbos, up-pipes, etc
Let me know what parts you need.
I have 32 total injectors. 28 will be sold as cores $103 each. 4 have less than 500 miles $250/each (genuine ford replacements). The newer ones are from the 03.
[email protected]
Price on the 2003 high pressure oil rails and front water pump housing.
$80 for the oil rails/log and $200 for the front cover. I'll inspect it for wear before shipping and ensure it's good to use.
price on a later model intake manifold, and 03 hpop pump....
$100 for the intake and $150 for the hpop
Top fuel filter assembly for 03?
You have any transmission dipstick tubes?
Should be the same
oilfield trucker
Heads from the 05?
Discussion Starter #14
I'll be pulling the heads on the low compression motor(s)to get magnafluxed, cleaned and pressure checked. Lookin for $1100/set after that.
SmokeyDiesel=HappyDiesel
Need a good front cover for an 05, also a cam. Got any? How much? Thanks!
Tim
I might need a front cover for 03/04.5 let me know how much. I got the oil filter housing from you it worked great thanks again
I'll need a set of 18mm dowel heads also
Discussion Starter #18
glad you got the parts. The 03 motor I have is still good so i'm gonna keep it complete.
I have a set of heads at the machine shop from an 04 being checked. I'll check with the machinest and see what the diagnosis is and the dowel size and get back to ya.
Ok sweet
1 - 20 of 30 Posts
