1 - 5 of 5 Posts
Working on changing all 3 cables on my truck. 97 swb ec. I'd would like to get part #s and or correct cable lengths. Parts house has several diff. lengths to choose from. I would just measure the ones on my truck but I think the po had the wrong ones put on, because parking brake has not worked since I've owned it.
I can't help you on part numbers for your truck (the only ones I've replaced were on the 94 CC DRW) . I did not have good a experience with aftermarket cables. The housings cracked allowing moisture to get in and causing corrosion and freeze-up in winter. I went back to factory cables and did not have problems with those. Just my experience. Cheers!
STILL LEARNING
Go to FORD and give them your wheel base
Aftermarket cables are pure crap
Couldn't agree more. The aftermarket crap will just frustrate you to no end. Sorry, I don't have a part number, but the guys at the service desk can hook you up.
1 - 5 of 5 Posts
