P2263 code
39K views 19 replies 4 participants last post by  Zane-03 King Ranch
#1 ·
Hey guys, I'm new to psn. Just recently picked up an 03 f-250 6.0 king ranch 100% stock. I bought this truck off a 70yr old couple out of spring hill fl. Needless to say after a week of a 23 yr old behind the wheel problems began to occur. I've since replaced u-joints and carrier bearing but at the moment iam having engine problems. I have a P2263 code. Truck has severe turbo surge at around 1800-2100 rpm between 55-65 mph but also happeneds upon other times as well. I have removed my turbo. Cleaned up the unison ring and veins and still problems persist. Inspected all cac connections and exhaust connections. I have not how ever checked my Ebp line or sensor. My reasonng behind this is when I start my truck in the morning it's in "LIMP" mode. Absolutely no power. If I let it idle warm up shut if off restart it it's fine I have regained power but the turbo surging and black smoke out the pipe continues. Any suggestions? Appreciate all the help ahead of time. My name is Zane by the way.
#2 ·
Ok, on the left side of the engine you will find a switch that has wires going to it, this switch has a tube connected to it that goes to the exhaust manifold. Its called EBP (exhaust back pressure) switch, remove to switch, start the engine and see if exhaust flows out this tube, if not the tube is plugged and that is you problem, clean it out or replace it.
If you had a scanner with live data you could watch that PID and see what is going on also. This is the first thing I would check.
#3 ·
Ill take it apart and check it out. I don't have a live scanner yet. Just dont see how cycling the key would remove limp mode from truck but I do know these 6.0 work weird
#4 ·
A ScanGaugeII is a great little set up. I am amazed at how much it does , it can see just about everything on a 6.0 engine. You should get one for monitoring the engine coolant temps and oil cooler temps if for nothing else.
The EBP is what the pcm uses for adjusting the vgt values for the turbo.
I am a bit suspect that your ICP or IPR may be the cause of the thing being in limp mode when you first start it up. May have crap piling up on IPR and shutting off the engine gets it to drop away and reposition when you restart it second time ???
Of coarse a ScanGaugeII will allow you to monitor the ICP and IPR values. May be a good time to pick one up. Auto Zone has them on the shelf for $160.00 and it will be the best money you will ever spend on the truck !
#5 ·
Yah I may need to because I just removed my Ebp line and sensor out after work tonight and it was clean. No clogs nuthin. of coarse I cleaned the line out since I had it removed but wasn't necessary
#11 ·
The only thing I can think of is that's left is the PCM/ECM. I was reading that it also has a baro sensor built into it. I did switch my PCM when I was doing some trouble shooting for another guy and my truck sounded different but I didn't think about checking the data.
So far I have a new baro sensor (one under the setterint colum), a new map sensor, and turbo was cleaned almost 30k miles ago but has been tuned since then. Also could be a problem with the VGT solenoid, but I've ran her on the boost test and it cycles fine. I have 99k miles on my truck right now.
#12 ·
You need to get a scanner that reads live data and your EBP, MAP, Baro sensor should all read the same at key on. Levels depend at what elevation you are and sometimes reading will be different because one is being displayed in PSI and the other in KPA. Make sure to convert them so they are all in the same measurement.
#14 ·
I've installed a new map sensor. And cleaned out my turbo/veins/ring. Only reason I don't think it's injector o-rings is even if I don't let it warm up I just start it shut it off and restart it it's fine. No more limp mode. No like it's in limp mode till warms up nd then it's good. I do need to get a live scann but with a girlfriend you could imagine where the money's want to spend on my truck usually goes. I do appreciate all your guys help tho. Is there a way to test the Baro sensor without getting a live data gauge? Wish my cummins insight program would work. Lol
#18 ·
Yeah I just bought a unison ring off a buddy of mine and will be replacing my Vogt selenoid soon. Hopefully that'll do the trick. Either way I still drive it. Just dont want to start my truck shut it off and restart it every time I get in it
#20 ·
Just picked up a scan gauge II. The other day. Right now I have ficm voltage at 48-48.5 at all times. Icp any where from 650-710 at idle and ect/eot difference is about 20 degrees when driving. Lol oil cooler time. So now that I have a scanner. Should I be monitoring icp?
