1 - 5 of 5 Posts
My ABS light has come and and I get a P215A code. I have read that the sensors may go bad but would it throw this code and how can I determine which sensor? Also, sometimes when I step on the brake, the pedal pushes back as if the ABS kicks in then the pedal will go down as usual. Any help would be appreciated.
Thanks, Jordan
We pulled the sensor out and it wsa clean and everything looked fine. When we hooked it up to the scanner it says left rear sensor but I thought there was only one ABS sensor in the rear? Are these prone to failure?
WWDD
I dont think there is anymore other than the one on the diff
There were quite a few people right off the bat that were having issues, some tuned, some stock. You might look and see if there is a sensor on each wheel but i dont think there is.
There is not a sensor at the rear wheels just on the diff. I ordered a new one and am going to pick it up and put it on and see how it does.
1 - 5 of 5 Posts
