1 - 12 of 12 Posts
I've had this code more than anything else over the last 20 years. Fussed with checking resistance on the glow plugs about 3-4 years ago and finally took it in and they replaced a bank of glow plugs. It's back again. Bank 1... (Passenger side right) Ohmed all 4 GP's through valve cover harness and readings are .5 to .8 ohms. Not sure what else to do. If they are all testing within range what next?
Doing some more testing the GPR is not shutting off. Engine is warm and it's about 70 degrees. Turn the key to on and I measure 12.4 volts across both GPR terminals and after 2-1/2 minutes relay is still on.
Moderator
on a cold engine block, the glow plugs can stay powered for up to 3 minutes depending on temperatures.
just because the wait to start light goes out, that does not mean the glow plugs are not still working.
IIRC the ohm spec 2.3-3.4 ohms
The ohm range for the ZD-11's is 0.6 and 2 ohms for good glow plugs.
How do your pass through connectors look when you pulled the connector off?
As for the relay not shutting off, have you checked it after a few minutes. As was mentioned they can stay on for up to 2 or so minutes even when the outside air temperature is 70 degrees.
I also noticed that you show that it is a Cal truck. Does it have a regular glow plug relay or does it have the shunt on top still?
If he doesn't chime in here send a PM to Patrick Feeley
I believe that he is one of the best on here for questions about a California truck
Project Shamu
The glow plugs will turn on even when the engine is warm sometimes, just not for very long. I've had a GPR fail on me a long time ago, and my truck didnt start when it was 90* outside, just white smoke out the exhaust.
So like the guys above said, make sure the GPR goes through its cycle. If the GPR didn't shut off for 5-10 min after starting, I'm assuming the wires would almost melt themselves apart, as they do draw a lot of power!
EDIT: A good read for some info on your Cali truck that I've saved; https://www.powerstrokenation.com/forums/17-1994-1997-power-stroke-technical-info/565047-7-3l-f250-difficulty-starting.html#post6162251
My truck would occasionally have the code too. I never knew what caused it, but I switched to a Wester Plow relay and have not had any issues in the years since. Make sure all connections at the shunt are clean and tight. I've attached a TSB regarding an issue with certain trucks as well as the Glow Plug System pinpoint tests. Cheers!
Thanks guys for all the feedback. I have one of those larger relays that I put on about 10 years ago. It may have finally started to fail. Amazon delivered a new one this afternoon so I’ll put that in and clear codes and see if that fixes it. Mine is a California truck with the shunt as well.
I don't think that the relay is the problem. If you are getting a bank code it may be a problem with the shunt.
If the relay was staying energized all the time you would quickly notice it when the truck was off with the battery draining in a short time.
Sent from my SM-J737V using Tapatalk
1 - 12 of 12 Posts
