1 - 7 of 7 Posts
train wrecker
:( i just got it after i changed my glow plugs. i only changed four for now, on the drivers side...gotta go to work. WHAT DID I DO?
it also started running rough.
HELP PLEASE, boots
train wrecker
Discussion Starter · #2 ·
anyone?
Edward Scissorhand WanaB
Make sure the under valve cover harness (UVCH) and all injectors are plugged in tight. The running rough might be the engine is running off only 4 cylinders.
train wrecker
Discussion Starter · #4 ·
i got it, thats what is was. it just came out a little bit.
thanks.
Cool Deal.
Sure is aggravating when something that simple can be the problem.
1997 Ford F250 HD 7.3 Diesel 4x4 ,4EOD trans, Upgraded Alternator, Western plow relay,
I'm having the same problem and I changed all eight glow plugs and a intake boot for the turbo and I know for a fact that my connections are all good don't have any idea what else it could be it says IDM couldn't read codes
Did not blow any oil out of the way before putting in new glow plugs
1 - 7 of 7 Posts
